Results 1 to 2 of 2
    Tac i/net Seven CD Key
    We have HVAC System with Tac i/net Seven 2.21 installed,There is virus in PC and we want to Format it.We have original CD but Key is not written on it,the person who install it long back left company and no other person knows Key. So anybody knows how to retrieve key before formatting or how to get Key.Thanks for any help.
    SE Wisconsin
    Can you contact your installing branch and see if they have a record?
    Can you find the disk case for the I/Net system? The code is printed on there. The certificate will have it also.
    Will you be reloading the original OS? If not, check the compatibility with your version.
    Without the case, certificate or branch help I'm not seeing many other options.
    Good luck!
