Results 14 to 26 of 41
    May 2012
    Upper Michigan
    I don't think the reeds would cause it not to fire at all, they work more at higher throttle.
    Jun 2009
    Upstate SC
    Check the stator . if one cylinder won't fire you have a ignition issue.
    Sent from my SCH-I510 using Tapatalk 2
    Altmar, New York, United States
    Quote Originally Posted by jdblack View Post
    it has great spark. i am not sure how it gets timed. i think it has a crank scensor, or trigger.
    Jun 2009
    Upstate SC
    Quote Originally Posted by snupytcb View Post
    Your post #7 said no fire at all.....
    The timing is typically done by the rotation of the stator under the flywheel. magnets in the flywheel excite the stator and send voltage to the coils. rotating the stator changes the timing. that backfire seems to indicate a timing issue. just see if you can get at the stAtor and see if its loose.
    Virginia
    115 psi ? Thats aweful low for a 2 cycle engine
    I like to see 150 , 140 is average
    Make sure both plugs are out and throttle is wide open when testing
    You might need to pull that flywheel off and see if the key-way is sheared in half , that will throw off your timing really bad
    Jan 2013
    Central, FL
    What is a snowmobile?
    Jun 2009
    Upstate SC
    Quote Originally Posted by Ductfisher View Post
    Its a jet ski for solid water types.
    May 2012
    Upper Michigan
    Quote Originally Posted by Snapperhead View Post
    I think 120 is more in line than 150, especially for an older sled. My race sled with 110 octane heads were like 160ish
    butler pa
    check and see if flywheel key sheared
    i agree, i have never seen a stock motor with that much compression. i am pulling the flywheel tomoroew. it is hot tub night tonight. we are kidless. we have a few other sleds so this one isn't a priority.
    Quote Originally Posted by Joehvac25 View Post
    May 2012
    Upper Michigan
    If you wake up in the 80s we need to hear the story here first ok?
    was htalk here then? i will do my best. maybe some pics of the rock'n concerts. man did they know how to rock back then or what?
    May 2012
    Upper Michigan
    My dads in a rock band so I know first hand about that stuff lol.
    I guess you didn't see the movie hot tub time machine? They make it back to the present.
