Results 27 to 39 of 41
  1. #27
    Mar 2009
    Mid-Mo
    115 psi ? Thats aweful low for a 2 cycle engine
    I like to see 150 , 140 is average
    Make sure both plugs are out and throttle is wide open when testing
    You might need to pull that flywheel off and see if the key-way is sheared in half , that will throw off your timing really bad
    The flywheel key is what I was thinking. Mowers are notorious for that if something didn't happen when it was supposed to.
  2. #28
    Altmar, New York, United States
    yes, you are right. but don't you loose spark all together?
  3. #29
    May 2012
    Upper Michigan
    With the stator not moving you shouldn't have spark. A 2 stroke isn't timed like a 4, there's no Valves. The spark plug just sparks continuously. I really don't remember ever having to deal with timing on a 2 stoke, it just spins and does its job.
  4. #30
    i think it has a crank cncor and the flywheel has a magnet. when they touch it sparks. i think this is how it works. it seems it has to be timed. if not i think it could spark at the top or bottom of the stroke and possably detonete. right?
  5. #31
    May 2012
    Upper Michigan
    When the piston hits the bottom there is no compression to make it fire. You may be right I never really got into that area on a 2 stroke
  6. #32
    i have to go fix the bobcat then i will check the flywheel on the sled. i have zero phone reception up there and no internet. it makes it hard. man, i think i was a better mechanic before i found the internet.lol
  7. #33
    Jun 2009
    Upstate SC
    Quote Originally Posted by snupytcb View Post
    If it fired before to early before TDC then the motor would want to spin backwards. Its a timed ignition.
    Sent from my SCH-I510 using Tapatalk 2
  8. #34
    Jun 2009
    Upstate SC
    Even with a sheared key it would spark when ever the flywheel passes the stator. There would be enough drag that the flywheel would turn even with a sheared key. The timing might get screwed though. all my two stroke motors had tapered shafts and woodruff keys.
  9. #35
    Fyi .... Ether , starting fluid , works great with diesels , but for your gas engine use gasoline and pour couple tablespoons down carb
    This coming from a fella been a mechanic for 25 years and work on both
    Yes that would be me : )
  10. #36
    i agree, but it was just for diagnostics. we worked at it for a little while last night. (the fridge git in the way.lol) we found it has a fuel delivery issue also. but i am headed up now, i want to concentrate on the ignition issue.
  11. #37
    butler pa
    if you have a manual..id check the static timing...spark at wrong time=no firing (assuming fuel system operating )
  12. #38
    i wish i had a manual.
    Quote Originally Posted by pauls heating & View Post
  13. #39
    funny thing with starting fluid .... sometimes it will make starting WORSE on a gas engine
    If you have fuel delivery issues , bypass all that to see if your ignition is ok , lets hear her run a few seconds
    Let that thing air out a few days with no plugs , then pour couple teaspoons fresh gas in the carb
    If you are trying to use gas thats been sitting around 6 months , its no good
    Todays gas with ethanol doesnt like to sit , it turns to worthless crap , it litterally loses its flamability
