Page 1 of 4 1234 LastLast
Results 1 to 13 of 41
    Altmar, New York, United States
    anybody good with older snowmobile engines?
    i have an old arcticat lynx 340 that won't run. my buddy was riding it and it was running great. he was putting in the barn and it popped through the carb and now it won't start.it had been sitting for three years so we went through the entire fuel system before even starting it the first time. it has great spark and gas to the plugs. one cylender is a little dry but should run. it won't even fire on starting fluid. any ideas? i am stumped. i have worked on these since i was a little kid and consider myself fairly good at it. but i don't know about this one. i am leaning toward timing.
    May 2012
    Upper Michigan
    Fuel spark and air are all you need, is it flooding, did you try new plugs?
    yup, used hotter plugs too.
    May 2012
    Upper Michigan
    Hmm seems strange, what I do sometimes is heat the plugs up and also put a torch in the cylinder to burn the fuel out then try some carb cleaner or pour some gas in the cylinder then try.
    Tallahassee, FL
    Quote Originally Posted by Joehvac25 View Post
    Also need compression. 2 stroke?
    May 2012
    Upper Michigan
    Quote Originally Posted by SBKold View Post
    I guess that's assumed since it ran before lol but I was going to mention yhat
    it had 115 on both cylanders. it is oil injected. i put gas in them and starting fluid. no fire at all. doesn't make sence.
    Tallahassee, FL
    Check the reed valves if it backfired.
    would i still have good compression if they are bad? the motor was rebuilt 4 years ago.
    May 2012
    Upper Michigan
    Did you try to bump start it yet? Lol jk
    lol.
    Tallahassee, FL
    Yes you could on the guage.
    May 2012
    Upper Michigan
    Seems odd that one cylinder won't even fire, try pulling the air filter off maybe, it's been awhile since I've done any wrenching.
