Thread: Next Tech Northeastern
12-07-2006, 05:46 PM #1
NextTechNortrheastern
Has anyone every heard or worked for this company? any comments good or bad, thanks."Correct Installation is the Key"
.1 has killed more HX then Rush Limbaugh
What is your TESP?
12-07-2006, 10:35 PM #2
its all about perspective
Do a search or look in the jobs area, its been beat to death over there a few times.
12-07-2006, 11:01 PM #3
What do you mean?
What is your TESP?
12-07-2006, 11:14 PM #4
I want to remain neutral
I've heard good & bad.
I know of good & bad.
If you like long hours, its good.
If you don't, its not good.
My only real problem with them is that they are performance oriented.
I suppose most companies are, the difference is they let you know on a regular basis where you & everyone else stands as far as the amount of revenue you bring in.
In reality, any good company will try to help those that are not as productive as others & if you continue to be unproductive they will let you go.
I just don't want to see situations where things like this are discussed to the point that it can cloud one's judgement.
I've already said more than I wanted to because I have friends that work for them & when they read this I'll hear about as it is.
Hope this helps.All my leon freaked out!
12-08-2006, 11:39 AM #5
Well, thank you for the info, Im deciding weather or not to take a postition with them. Them money is good, but my impression was kind of the same as you described it. Thanks again!
What is your TESP?
