Page 3 of 3 FirstFirst 123
Results 27 to 37 of 37
  1. #27
    in a house, Appomattox, Va.
    I have the testo dual port I won off this site yrs ago, one of my favorite tools.
    Before then I had a Dwyer oil filled incline manometer and u-tube manometer. The Mark II I had was about $30 and I used it to meas ESP when doing install startups to check airflow.
    I've also used dt to set airflow when had elec htrs in unit.
    w/o either elec ht or static chart, fall back on the pitot tube I keep on van. also have a phototach that I've used on commercial stuff. on res w/driecrt drive, the rpm=motor speed, so and oem esp chart just uses esp and motor speed tap on chart.
    since comm stuff has lots of belt drive, they use blower rpm. bit of scotchbrite and esp and can use cfm chart.
    Col 3:23
  2. #28
    Jan 2012
    Tallahassee,Fl
    Quote Originally Posted by Eadam1985 View Post
    i just bogh fieldpiece 2 port manometer only had a chance to use it a few time but love it!
    What I use no problems.
  3. #29
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by Northfloridatech View Post
    I use the field piece as well. I like it but when checking gas pressure it will drop below the actual reading and I constantly have to re-zero to make sure it is right. Not sure if they are all like that or just mine. It's not a big deal now but when I first used it I unknowingly set gas pressure too high.
  4. #30
    Mar 2011
    Birmingham, AL
    Can you hook up 'static probes' or a 'pitot tube' to a 'yellow jacket 78055 gas pressure test kit' or do you have to use a manometer?
  5. #31
    Quote Originally Posted by filiberto View Post
    The YJ 78055 only reads positive pressure, and the scale is too big (0 - 10"wc.) for accurate readings.
    If you are using an analog dial gauge, you need something that is a dual port (positive, negative or differential) gauge where the scale is only 0 - 1" wc (0 - 2"wc max) for accurate static pressure readings. Something like the Dwyer #2001.
    You also need a dual port manometer when using a pitot tube.
  6. #32
    Mar 2012
    west burb IL
    My Testo 510 has been serving me well so far.
  7. #33
    Mar 2011
    Birmingham, AL
    Aha! Excellent concise info. Thanks rundawg!
  8. #34
    Nov 2011
    Philadelphia, PA
    Quote Originally Posted by millertime77 View Post
    A pitot measures both total and static pressure. It is concentric with the inner tube measuring total and the outer tube surrounds the inner and has several tiny holes and connected to the other end of a manometer. I also have the Testo 510 pocket pro, and was wondering how a pitot would work with it as far as how you would connect the inner and outer protions of the pitot? Also, when I bought mine it didn't come with any tubing or attachments and I am looking for a kit, something with a pitot and different sized static tips. Don't mean to jump in on someone else's thread but any of you guy's(gals) have any suggestions for that?
    I was surprised it didn't come with hoses also. You can google static pressure kit and a bunch of stuff comes up. I went to home depot and found 3/8" tubing 20 feet for only 2 bucks.
  9. #35
    Nov 2011
    Philadelphia, PA
    Quote Originally Posted by billygoat22 View Post
    You can win tools off this site!?!? I want to win something. Where do I sign up
  10. #36
    Jan 2013
    California
    Quote Originally Posted by 2141 View Post
    I use the Fieldpiece dual port as well. Mine does the same with the gas pressure (about .1"WC every few minutes), but it works great for static pressure. The other issue I have is if I leave the hose on the port, it makes it easier to break the port off the meter! Thankfully it has two ports...
  11. #37
    The best on the market is the retrotec DM-2 for checking minute pressure imbalances throughout a structure and for blower door/duct leakage testing. Testo 510 for gas pressure, draft and duct static. The testo kit I got came with pitot tubes, leather case that hooks to your belt and a cloth carrying case for hoses, pitot tubes, manometer and instruction manual.
