Results 27 to 37 of 37
Thread: best digital manometer
01-03-2013, 08:40 PM #27
I have the testo dual port I won off this site yrs ago, one of my favorite tools.
Before then I had a Dwyer oil filled incline manometer and u-tube manometer. The Mark II I had was about $30 and I used it to meas ESP when doing install startups to check airflow.
I've also used dt to set airflow when had elec htrs in unit.
w/o either elec ht or static chart, fall back on the pitot tube I keep on van. also have a phototach that I've used on commercial stuff. on res w/driecrt drive, the rpm=motor speed, so and oem esp chart just uses esp and motor speed tap on chart.
since comm stuff has lots of belt drive, they use blower rpm. bit of scotchbrite and esp and can use cfm chart.Col 3:23
01-03-2013, 09:50 PM #28
01-03-2013, 10:05 PM #29
- Jul 2012
- Cincinnati ohio
- 101
I use the field piece as well. I like it but when checking gas pressure it will drop below the actual reading and I constantly have to re-zero to make sure it is right. Not sure if they are all like that or just mine. It's not a big deal now but when I first used it I unknowingly set gas pressure too high.
01-05-2013, 12:32 AM #30
- Mar 2011
- Birmingham, AL
- 21
Can you hook up 'static probes' or a 'pitot tube' to a 'yellow jacket 78055 gas pressure test kit' or do you have to use a manometer?
01-05-2013, 09:35 AM #31
The YJ 78055 only reads positive pressure, and the scale is too big (0 - 10"wc.) for accurate readings.
If you are using an analog dial gauge, you need something that is a dual port (positive, negative or differential) gauge where the scale is only 0 - 1" wc (0 - 2"wc max) for accurate static pressure readings. Something like the Dwyer #2001.
You also need a dual port manometer when using a pitot tube.Instead of learning the tricks of the trade, learn the trade.
01-05-2013, 09:58 AM #32
- Mar 2012
- west burb IL
- 76
My Testo 510 has been serving me well so far.
01-05-2013, 10:12 AM #33
- Mar 2011
- Birmingham, AL
- 21
Aha! Excellent concise info. Thanks rundawg!
01-05-2013, 07:54 PM #34
- Nov 2011
- Philadelphia, PA
- 143
01-05-2013, 07:56 PM #35
- Nov 2011
- Philadelphia, PA
- 143
01-05-2013, 08:00 PM #36
I use the Fieldpiece dual port as well. Mine does the same with the gas pressure (about .1"WC every few minutes), but it works great for static pressure. The other issue I have is if I leave the hose on the port, it makes it easier to break the port off the meter! Thankfully it has two ports...
01-05-2013, 08:01 PM #37
The best on the market is the retrotec DM-2 for checking minute pressure imbalances throughout a structure and for blower door/duct leakage testing. Testo 510 for gas pressure, draft and duct static. The testo kit I got came with pitot tubes, leather case that hooks to your belt and a cloth carrying case for hoses, pitot tubes, manometer and instruction manual.
