Results 1 to 7 of 7
    Windsor Ontario
    Payne no blower during heat.
    I looked at a friends payne pg9mtav36075abss furnace the other night. The blower will not come during the heating cycle unless you turn the fan to on. I dont have much experience with the new furnaces with the ecm motors as I do primarily comercial and industrial work. I am suspecting the blower control board. Has anyone else had this issue with the new Payne furnaces?
    May 2012
    Upper Michigan
    I don't think that has a ECM blower. So the board won't turn the blower on in heat mode but when you turn stat to on it runs? We aren't supposed to give DIY advise here more so people can't google the answers. Can you go pro?
    Edit I see you have the 15 posts required, in the closed forums you will get better answers
    butler pa
    sure its an ecm motor ?
    Quote Originally Posted by tech-c2 View Post
    T = 2 Stage
    V = Variable Speed ECM Blower
    The control board does control the blower "ON" and "OFF" in Heat and Cool modes.
    There are many dip switches on the control board for setting blower speeds. I would find the install manual and make sure it is set up properly, then do some VOM testing, before I'd condemn the board.
    As, Joehvac25 said, we can't go into too much detail in this "OPEN" forum. Apply for Pro membership, you won't be disappointed.
    May 2012
    Upper Michigan
    Quote Originally Posted by rundawg View Post
    T = 2 Stage
    Ok I was thinking the older Payne single stage secondary killers lol
    Windsor Ontario
    Thanks Guys I have been meaning to go pro I better get on it.
    May 2009
    Cumming, GA
    It may be in the thermostat settings. Get a pro membership and we will discuss further on the "other side."
