Results 1 to 13 of 18
Thread: Tankless
    Apr 2012
    Cleveland
    Tankless
Size:  61.9 KBName:  ImageUploadedByTapatalk1356979696.739563.jpg
Size:  17.6 KBName:  ImageUploadedByTapatalk1356979704.656211.jpg
    Tankless job my bro in law put in
    Jan 2013
    Just out of curiosity, what are the energy savings between a tank heater and a tankless? And the price between the two.
    Nice, clean install though.
    Sent from my SCH-I535 using Tapatalk 2
    Jan 2011
    Boston, MA
    Quote Originally Posted by access_max View Post
    Idk any actual numbers but the theory is your only heating the water when you need it. Instead of keeping say 40 gallons hot 24/7.
    Comfort also comes into play. You really don't have to worry about running out of hot water.
    Jan 2011
    Boston, MA
    Very nice install btw
    Apr 2012
    Cleveland
    They can get up to 98% so they can definitely save some money. I'm far from an expert on them I only work on a few a year. Initial cost can be quite a bit higher. One of the complaints I've heard about them is it takes longer to get hot water especially farther away from the unit because the pipes stay cold and you need to run that water out first.
    Apr 2012
    Cleveland
    Quote Originally Posted by FrostyBeer View Post
    Thank you
    Jan 2013
    Quote Originally Posted by Hvac216 View Post
    Isn't it the same issue with a tank water heater?
    Dec 2008
    Ontario Canada
    But with a tankless you have to also wait for the burner prepurge and light off. A tank gives warm water right away. This also sometimes gives a "cold water sandwich"
    Aug 2001
    Pavilion, NY
    That's a pretty small gas line.. How long it that csst? Looks like 3/4".. Natural gas?
    Apr 2012
    Cleveland
    Quote Originally Posted by kangaroogod View Post
    Yeah 3/4 to a tee at the ceiling, around 6ft I think. From there it goes to hard black pipe. 3/4 is all those units require as long as you have 1 1/4 from the meter and its the 1st gas appliance. Oh and yes natural gas.
    A couple guys from work went to a class and the newest ones coming out will run on 1/2". It doesn't matter if its before or after other appliances as long as it gets 3.5" inlet.
    They can save on gas but if you factor in first cost, maintenance and repairs you
    don't have with a tank, is the net result savings? Not if you lose a $xxx board!
    Sent from my HTC VLE_U using Tapatalk 2
    Apr 2012
    Cleveland
    That's not much different then high end hvac systems. 16 seer 2 stage, mod furnace, and a couple repairs and there go all your savings.
    Jan 2013
    Agreed, cheaper to repair a cheaper hot water tank, than spend more upfront on a nifty tankless loaded with features that will break at some point that costs $$$ to fix, and bam, all the savings you saved up, evaporate.
