Results 1 to 13 of 13
    Dec 2006
    South Carolina
    Smile Best heat load software
    I would like to hear anyones opinion on a good heat load calculatiion software. I am at a point where I could go into buisness for myself, but do not have the time to go back to school to learn man j /d . I have 7 yrs in the buisness and mainly do change outs. I am a Firefighter and really just want to use hvac work as a supplemental income, however I want my work to be A PLUS, as I have always been taught to do the best job I can. Thank you for any advice!
    Oct 2002
    Florida Panhandle
    Go to top of this page and click Hvac Calc.
    Roy
    A man is no less a slave because he is allowed to choose a new master once in a term of years.
    Lysander Spooner
    Dec 2006
    I have used Wrightsoft for 7 yrs and love - i have tried others like elite and just didn't find it as accurate and user friendly. Some local jurisdictions only allow certain programs to be used within their areas also- so make sure to contact your local building authority and make sure of that.
    David Wilson
    Dec 2006
    I downloaded HVAC-CALC (again, at the top of this page)a couple of months ago for use on my own abode. As a novice to the HVAC world, I found it an intuitive piece of software. Most everything is explained in the accompanying instructions, you just need to fill-in the blanks as shown by the included tutorial. The one thing I changed was the suggested setup parameter showing the coldest temprature here in Smyrna, GA as -15 Degrees (I used zero F). Okay, maybe once in a century it hits -15...
    The software does allow you to choose flex or rigid duct, and will give a PDF file output showing recommended duct sizes per room. Highly recommended.
    Hope this helps.
    SW FL
    wRIGHT Soft
    Let me know your needs via e-mail (see my credentials)
    Designer Dan
    Lackster : -15 ODT anywhere in Georgia???
    I just scrolled through all Georgia city design conditions provided in HVAC-Calc and none advised a winter temp below +22 Deg F.
    -15 Deg F would be reasonable in parts of northern New England or the upper Midwest, but certainly nowhere in Georgia or any adjacent state...
    Sep 2003
    Click the bullseye at the top of the pa... Hey! Where'd the bullseye go???
    HVAC-Calc for me. If you want to be punished use ResCheck.
    Dec 2006
    WATERCOP...
    You are correct. I fired up my HVAC CALC program and used the Marietta-Dobbins (Air Reserve Base) location (I hear the sound of freedom flying overhead at all hours - sweet!).
    My version 4.0.50 defaults to 21 F winter, 92 F summer outdoor temps.
    My appologies to Don Sleeth. I guess this means I have NO issues with the software. Just read the instructions carefully.
    Jul 2014
    Apache Junction, Arizona
    testing it myself now
    SW FL
    The Best Software that I am aware of Is MINE.
    L.O.L.
    Designer Dan
    Mar 2009
    Mount Holly, NC
    Well... What part of SC are you in?
    They use the IMC 2012 code, so you will need to be versed in it to pass your license, you will need to show journeyman experience in the field for 2 years to take the test... I'm looking to increase my licensing creds to cover SC, so, drop me an email if ya wanna buddy up prepping for the test...
    Quote Originally Posted by ffswany View Post
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    This is an 8 year old thread.
    Jul 2014
    I have not been here that long so I highjacked it instead of starting a new one..:-) my search for a good software program is very current..
