Results 1 to 7 of 7
    Dec 2012
    Question Two PVC pipes coming out of furnace... one has hole in it? Water dripping... Help!
    Hey guys,
    Read some great posts here in the past now I have a question of my own.
    I am noticing some water dripping from the bottom of one of the PVC pipes that exit (enter?) the furnace. Originally I was worried I had a leak at the roof and it was following the pipe down but today I notice one pipe has a hole in it and I believe condensation is running out also the higher parts of the pipe feel dry.
    This seems wrong to me, either the exhaust or intake pipe is in the house right? Neither of those seems proper.
    Please let me know if it makes sense for this hole to be there.
    Thanks you much,
    -Ben
    Combustion test hole. it should be sealed. You can use caulk to seal the hole.
    Dec 2012
    Thank you, will do immediately.
    Jan 2011
    Metro Atlanta
    use duct tape , easier to reuse test hole if needed :-)
    The opinions expressed by me are not that of my employer.
    insulation modern marvels
    http://www.youtube.com/watch?v=g37riSkyZzM
    St Paul, minnesota
    or better yet use foil tape
    Quote Originally Posted by NY2GA01 View Post
    Jan 2011
    Metro Atlanta
    Quote Originally Posted by superfittertech View Post
    Or better yet, clear packing tape. Most homes have some 200 mph tape around the home.
    Feb 2012
    Toronto Canada
    Use the gum from your Mouth
