Results 1 to 13 of 20
12-29-2012, 10:57 PM #1
- Aug 2012
- 6
Without a compressor will coil cool slightly?
I was wondering in theory if there was no compressor in an ac system when it is hotter by the condesor coil would the evap coil cool the room at all since heat will still transfer through the pipes.
12-29-2012, 11:01 PM #2
Heat wont transfer if there is no temperature difference. The refrigerant will take on the temperature of the ambient. If the temp in the house is 80* the refrigerant will be 80*
Local 597 Service Fitter
Metal Trade Journeyman
PAY ME NOW OR PAY ME LATER
It was working when I left...
WWFD
12-29-2012, 11:02 PM #3
If the system could thremo-syphon it would heat the room.
Energy travels from more to less.
12-29-2012, 11:51 PM #4
Gh
12-30-2012, 12:33 AM #5
- Aug 2012
- 6
I made a mistake. If it is colder outside than inside and there is no compressor would the heat transfer through the pipes outside.
in another scenario if the outside coil was 100 times the size of the inside coil would the inside space be cooled even if it was hotter outside.
12-30-2012, 12:46 AM #6
Question one, yes is possible and can be designed to achieve this, Star Refrigeration, Scotland, designed a valve and system to achieve this in the industrial refrigeration field. You could also look up heat pipes, (like you see in some solar systems) as also used in air cooling. Quite common in remote telecommunication transmission stations
Question 2
No
12-30-2012, 01:05 AM #7"Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
12-30-2012, 12:07 PM #8
- Jun 2001
- Moore, Oklahoma
- 2,596
You would need to have some type of circulator to move the fluid. I suppose it could work w/o an expansion device and a small circulator in place of the compressor. Don't know why anybody would want to do this though...
12-30-2012, 01:39 PM #9
If its colder outside than inside, why not just open a window? Or an economizer?
12-30-2012, 03:55 PM #10
I think he feels his unit is still cooling, even though the compressors shot.
Most likely because the fan is running, and making him FEEL cooler."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
Dad adjusted
12-30-2012, 05:06 PM #11
you dont need a compressor. just something to raise the refrigerant pressure before the condensor.
IV IV IX
use your head for something other than a hat rack.......Gerry
12-30-2012, 06:39 PM #12
It isn't really possible to break the laws of thermodynamics.
The one in play here is that heat moves from an area of high content to an area of low content.
So, if it is warm outside and cool inside, the direction of natural heat flow is from outside to inside. A compressor is required to operate the refrigerating machine that moves the heat opposite normal flow.
A heat pipe or thermosyphon, as mentioned earlier can be setup to move heat, but isn't exactly practical, IMO, nor is it likely to happen naturally in a beneficial manner for you.
12-30-2012, 06:49 PM #13
- Jun 2001
- Moore, Oklahoma
- 2,596
