Results 1 to 6 of 6
    Older Wayne oil burner
    I was on an older wayne oil burner and found the fuel pump seized. Pump is single stage and has no markings on it whatsoever. From my understanding, the older pumps are 1725 rpm. This one is direct drive. I also heard belt drive are mostly 1725 rpm. How do I know for sure whether to choose a 1725 or 3450 rpm pump if there is no written indication of what is required? I just don't want to assume. Thank You
    and the burner motor is????
    Quote Originally Posted by dandyme View Post
    X2
    if you still do not get it, maybe you need a professional to complete the work.
    Wow, I feel stupid, excuse me while I crawl under a rock and die.
    do you understand the reply?
    just trying to guide you to the answer without telling you the answer.
    May 2012
    Upper Michigan
    Quote Originally Posted by hvac/airplanes View Post
    If you don't feel stupid sometimes your not trying hard enuf.
    What everyone else said x4
