Results 1 to 13 of 20
Thread: Found this on a heat pump
12-28-2012, 09:04 PM #1
Found this on a heat pump. need I say what's wrong? Not sure if this is what killed the compressor or not.
The opinions expressed by me are not that of my employer.
12-28-2012, 09:16 PM #2
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,254
you'll know when you cut that puppy out of there.
12-28-2012, 09:26 PM #3
What's the difference between a bi-flow and a uni-directional? Would a uni-directional prevent flow in the opposite direction?
"The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
"Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
http://www.campbellmechanical.com
12-28-2012, 09:28 PM #4
What?
I replaced it with the correct bi flow filter drier when I replaced the compressor today. I can't believe it took a few years to kill the compressor.
Yes it would.
http://www.thefreedictionary.com/unidirectional
12-28-2012, 11:02 PM #5
Lol. It might help to have a bi flow. I went to a call after a fellow tech installed a straight cool filter/dryer backwards. I showed it to him. and he blew through it backwards and said "whats the difference"? I said blow through it at 250 psi
12-28-2012, 11:17 PM #6
So what direction did he choose?
12-29-2012, 12:33 AM #7
The 250 psi is relative to atmospheric pressure. The differential pressure across the drier is almost zero. So the amount of resistance to flow should be no different than blowing through it with your mouth.
I think the difference is in the configuration of the screens and desiccants."The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
12-29-2012, 01:10 AM #8
12-29-2012, 10:17 AM #9
- Dec 2002
- 7,254
did anything fall out of the drier when you removed it (hopefully you cut it out instead of unsweating it)?
12-29-2012, 05:41 PM #10
12-29-2012, 06:38 PM #11
12-30-2012, 11:37 AM #12
Got a walk-in freezer out there that's been running for at least 10 years with the dryer piped in backwards. I think it just doesn't filter properly being installed in the wrong direction and has no affect on flow!
12-30-2012, 01:15 PM #13
