Results 1 to 13 of 20
    Jan 2011
    Metro Atlanta
    Found this on a heat pump
    Found this on a heat pump. need I say what's wrong? Not sure if this is what killed the compressor or not.
    The opinions expressed by me are not that of my employer.
    insulation modern marvels
    http://www.youtube.com/watch?v=g37riSkyZzM
    you'll know when you cut that puppy out of there.
    Eugene, Oregon
    What's the difference between a bi-flow and a uni-directional? Would a uni-directional prevent flow in the opposite direction?
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Jan 2011
    Metro Atlanta
    Quote Originally Posted by dandyme View Post
    What?
    I replaced it with the correct bi flow filter drier when I replaced the compressor today. I can't believe it took a few years to kill the compressor.
    Quote Originally Posted by air1 View Post
    Yes it would.
    http://www.thefreedictionary.com/unidirectional
    http://www.youtube.com/watch?v=O_05qJTeNNI
    May 2012
    Grand Junction, CO
    Lol. It might help to have a bi flow. I went to a call after a fellow tech installed a straight cool filter/dryer backwards. I showed it to him. and he blew through it backwards and said "whats the difference"? I said blow through it at 250 psi
    Dec 2008
    Ontario Canada
    So what direction did he choose?
    Eugene, Oregon
    Quote Originally Posted by GJ-HVAC/R View Post
    The 250 psi is relative to atmospheric pressure. The differential pressure across the drier is almost zero. So the amount of resistance to flow should be no different than blowing through it with your mouth.
    I think the difference is in the configuration of the screens and desiccants.
    Dec 2011
    New Zealand
    Correct.
    did anything fall out of the drier when you removed it (hopefully you cut it out instead of unsweating it)?
    Jan 2011
    Metro Atlanta
    I did cut it out, and no, nothing came out.
    May 2012
    Upper Michigan
    Quote Originally Posted by NY2GA01 View Post
    Maybe he thought your supposed to replace it every spring and fall.
    Phoenix,AZ
    Got a walk-in freezer out there that's been running for at least 10 years with the dryer piped in backwards. I think it just doesn't filter properly being installed in the wrong direction and has no affect on flow!
    Jan 2011
    Metro Atlanta
    Quote Originally Posted by KB Cool View Post
    but this was a heat pump, so the use of a one way filter is like having no filter at all.
    Still not a 100% on if it killed the compressor.
