Results 1 to 13 of 15
    Oct 2005
    Louisiana
    Lennox Package Unit Model# TGA120S2BH1Y (Gas Heat) NO HEAT
    My partner went on a service call for this unit because the heat wouldn't come on. It has 2 boards on it and the board with the indicator light is blinking 3 times. On the unit, it says that if the light is blinking 3 times is is usually flame overthrow but he checked it and it checked out ok. He has ordered a new board but we are hoping someone has info or troubleshooting advice on this unit. We're not too familiar with Lennox units.
    Oct 2011
    Chicagoland Area
    What is flame overthrow?
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Oct 2012
    La Crosse, WI
    I think it is rollout. Does that have the manual-reset rollout in it. Where the terminals corroded and not making a good connection?
    Oct 2011
    Chicagoland Area
    If that's the case, there is much more that needs to be checked
    WWFD
    Apr 2012
    winnipeg
    flame what...... never heard of the term in all my life..... good luck .......
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by carmon View Post
    Overthrow
    WWFD
    Apr 2012
    winnipeg
    oh now I get it .....
    Quote Originally Posted by starkey View Post
    The 3 flash code - Flame Rollout Switch Open or Prove Switch Open or Closed.
    The Flame Rollout is a 290ºf (+/- 12ºf ), manual reset switch.
    The Combustion Air Prove Switch closes on negative pressure fall, showing the inducer motor is up to speed before allowing the ignition sequence to continue.
    Did you have the door/panel back on burner compartment when you were testing?
    Did you do any testing of the combustion blower or it's capacitor?
    Sorry, but I don't post manuals in this "OPEN" forum.
    Feb 2007
    Central NJ
    I always check the circuit path from the molex plug connection(s), just because the roll out is closed doesn't mean it's finishing
    Southeastern Pa
    We don't discuss step by step diagnostics in the open forums. Get your post count up to 15 and apply for pro membership, so we can deal with your questions in the restricted access Pro forums.
    Even the T series has a wiring diagram. I would follow it and everything should be clear. What is the serial number?
    hell, he's a one & done, apparently didn't get the answer they wanted.
    and I'm a little concerned about the "partner" thing?????
    Southeastern Pa
    Quote Originally Posted by dandyme View Post
    I don't think Louisiana is one of "those" states...
    Oct 2011
    Chicagoland Area
    In Loozy they call them "Pardners"
    WWFD
