Results 1 to 13 of 15
12-28-2012, 06:14 PM #1
- Oct 2005
- Louisiana
- 1
Lennox Package Unit Model# TGA120S2BH1Y (Gas Heat) NO HEAT
My partner went on a service call for this unit because the heat wouldn't come on. It has 2 boards on it and the board with the indicator light is blinking 3 times. On the unit, it says that if the light is blinking 3 times is is usually flame overthrow but he checked it and it checked out ok. He has ordered a new board but we are hoping someone has info or troubleshooting advice on this unit. We're not too familiar with Lennox units.
12-28-2012, 06:59 PM #2
What is flame overthrow?
Local 597 Service Fitter
Metal Trade Journeyman
PAY ME NOW OR PAY ME LATER
It was working when I left...
WWFD
12-28-2012, 07:04 PM #3
- Oct 2012
- La Crosse, WI
- 233
I think it is rollout. Does that have the manual-reset rollout in it. Where the terminals corroded and not making a good connection?
12-28-2012, 07:14 PM #4
If that's the case, there is much more that needs to be checked
WWFD
12-28-2012, 09:33 PM #5
flame what...... never heard of the term in all my life..... good luck .......
12-28-2012, 09:39 PM #6
12-28-2012, 09:48 PM #7
oh now I get it .....
12-28-2012, 10:19 PM #8
The 3 flash code - Flame Rollout Switch Open or Prove Switch Open or Closed.
The Flame Rollout is a 290ºf (+/- 12ºf ), manual reset switch.
The Combustion Air Prove Switch closes on negative pressure fall, showing the inducer motor is up to speed before allowing the ignition sequence to continue.
Did you have the door/panel back on burner compartment when you were testing?
Did you do any testing of the combustion blower or it's capacitor?
Sorry, but I don't post manuals in this "OPEN" forum.Instead of learning the tricks of the trade, learn the trade.
12-29-2012, 08:58 AM #9
- Feb 2007
- Central NJ
- 366
I always check the circuit path from the molex plug connection(s), just because the roll out is closed doesn't mean it's finishing
12-29-2012, 08:23 PM #10
We don't discuss step by step diagnostics in the open forums. Get your post count up to 15 and apply for pro membership, so we can deal with your questions in the restricted access Pro forums.
Even the T series has a wiring diagram. I would follow it and everything should be clear. What is the serial number?[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
12-29-2012, 09:01 PM #11
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,211
hell, he's a one & done, apparently didn't get the answer they wanted.
and I'm a little concerned about the "partner" thing?????
12-29-2012, 09:20 PM #12[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
12-29-2012, 09:37 PM #13
