Results 1 to 13 of 18
    Dec 2012
    West Virginia
    What's missing??
    Had a no heat call, this is what I find.
    Eugene, Oregon
    Did the home owner remove the pressure switch? I can't believe a tech would do that.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Dec 2012
    West Virginia
    Home owner did it, said it's ran fine like that for awhile. Couldn't get through to him how unsafe it is. Knew everything.
    Cincinnati, Oh
    Ahh, the old jerry rigged trailer unit.
    Sad. Just sad.
    "Just get it done son."
    Dad adjusted
    Dec 2012
    West Virginia
    You nailed it hvacvegas.
    Athens, Ohio
    Missed an opportunity to thin the herd.
    Apr 2012
    winnipeg
    wow ...that is just plain wrong....
    Aug 2001
    Pavilion, NY
    Dude I have not laughed like that in a while! Thanks for the laugh.....thin the herd
    May 2011
    Western, KY
    Those trailer units always have something special in store for you
    May 2012
    Upper Michigan
    Quote Originally Posted by mason View Post
    They usually double as "the bat cave"
    Nov 2011
    St. Louis
    How does this even work? Doesn't the logic in most systems check to see that pressure switches are open at the beginning a cycle and then closed after at some point after the inducer is energized???
    Jun 2011
    Central Indiana
    Quote Originally Posted by hurtinhvac View Post
    Thats a good observation. I have been on more rigged trailer furnaces than I can count.
    The only true knowledge is the pursuit of knowledge
    May 2011
    Western, KY
    You're giving these units too much credit, they aren't that smart.
    If I'm remembering correctly this unit has an ignition box that only cares about flame signal and closed safeties, if it's getting the 24v to the box it's good, so let the removal and jumping out begin!
