Results 1 to 4 of 4
12-27-2012, 09:23 PM #1
- May 2011
- North Dallas, TX area
- 49
Hacking Carrier Greenspeed Wifi Thermostat?
I've got the 5-ton Carrier Greenspeed HeatPump (and love it) and just recently got the WiFi version of the thermostat installed.
One thing I've been longing to do (since I'm an engineer
) is to record how often my system is running at the various speeds (the thermosts record from 40% to 100% in 1% increments).
Does anybody know if there's a way to set this system up as a local network connection and be able to poll/record the run speed to create graphs/charts/etc later?
12-28-2012, 05:08 PM #2
Professional Member*
- Feb 2009
- Portland OR
- 1,510
Not a chance you can. Granted, I have not used their stat so I can not say with 100% certainty, but we do install a lot of the waterfurnace 7 series variable capacity communicating stats and Trane XL950/900 communicating stats and I can assure you their communicating protocol is proprietary and very secretive. We have had a customer try as well as one of our technicians and all they end up doing is shorting control boards and thermostats so be warned. You will void your warranty and you very likely will be buying either a new control board or thermostat and they are fairly spendy.
12-29-2012, 10:37 AM #3Bear Rules: Keep our home <50% RH summer, controls mites/mold and very comfortable.
12-30-2012, 09:27 AM #4
Onset Hobo VS ac Aug WI.pdf
Attached is a pdf of the Onset Hobo data logger U12-012 with the amp sensor. Data is collected every 5 mins. Can be more often. The pdf is made from the Hobo graph.
If you go that far, post the graphs, include the %RH during winter and summer.
This home includes fresh air ventilation. This data is without the whole house dehumidifier operating.
Regards TBBear Rules: Keep our home <50% RH summer, controls mites/mold and very comfortable.
