Results 1 to 13 of 23
    Buderus GB142 Multi Family / Retail
    I can't take credit for any of the piping or much else....
    I'm just the wiring and start up monkey!
    GB142-60
    7- Callefi "pop top" zone valves
    2- Honeywell Wireless Pro6000 tstats
    5- Honeywell Pro5000 tstats
    Boiler Buddy
    Grundfos Magna System Pump
    Spirovent
    100+ gallon indirect tank
    Don't have any before pics, sorry. It was originally a cast iron boiler (constant temp) with 4 zones (pumps). We re-piped the entire boiler room and split up the system to make 7 zones as the four apartments upstairs were originally controlled by only 2 thermostats and two of the retail shops downstairs were controlled by 1 stat.
    I thought this job turned out pretty well considering it was a bit of a rush.
    Any critique?
    Click image for larger version.
    Madison, Wisconsin
    looks nice
    clean
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Sep 2012
    thomaston, ct
    That's a lot of gas man! How do they split up the gas bill?
    Install looks nice and clean though.
    Would have taken the five minutes to paint the board though.
    In a boiler room
    Nice clean boiler work!
    Could have saved a pump by just using the buffer tank as your hydraulic seperation. I know, the low loss header comes with the boiler, which is why it always gets used.
    May 2012
    Upper Michigan
    They want check valve right at tank, all four ports so no gravity flow.
    In a boiler room
    Quote Originally Posted by Joehvac25 View Post
    No need for check valves. Gravity flow won't happen with zone valves on the supplies. Or did you mean something else?
    May 2012
    Upper Michigan
    Quote Originally Posted by chuckcrj View Post
    I have seen it go up the returns even. All the buffer tanks I've installed have 4 check valves right in the manual. I agree that with zone valves you won't get any after them. Not sure but maybe even the boiler side could a little also. If I'm wrong it won't offend me to school me chuck, I know you know your beans.
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    Couldn't afford a coat of paint on the plywood?
    A boiler drain between the ball valve and the x-tank would be nice for service.
    I love my job, but paydays Thursday
    In a boiler room
    I guess I don't understand why they would need any check valves in this application (other than the primary loop and the DHW loop of course). Gravity flow, if even possible on the boiler side, would not have any negative effect that I can think of.
    But I've been wrong before!
    May 2012
    Upper Michigan
    I guess at long off periods the highly insulated tank could lose heat and fire the boiler, but after a closer look there is no aquastat on the buffer tank so I guess that wouldn't be an issue. We set them up with outdoor reset and Teckmar control so the boiler maintains tank temperature. Not to hijack but here's one I did.Click image for larger version.
ID:	340741Click image for larger version.
    In a boiler room
    Nice work!
    May 2012
    Upper Michigan
    Nice work!
    Thanks, I enjoy this stuff!
    Jun 2002
    south jersey
    Do the install guys know you are putting up pictures of there work?
    You need to put the phone down and get back to work!
