Results 1 to 13 of 16
    Oct 2012
    No room to remove blower motor
    We have an air handler installed with the ductwork 12 inches from the access panel. Because its so close, the blower assembly cannot be removed and there is no way to sneak around to loosen the collar on back of the cage.
    I want to avoid removing the section of duct so the next best thing is to cut hole in rear panel then cover with ductmate sandwich door.
    I'd like to get some other ideas. Help !!
    Anthony
    May 2009
    Cumming, GA
    Is it in a attic, crawl space, mechanical room or closet? Describe the install a little better. Pictures would help a ton!
    Over the summer, I had a 2 year old 3 ton split with a faulty TXV. Problem was that you couldn't access the coil at all. So, I quoted the customer to remove the AHU, replaced TXV, and then reinstall with correct service access. We got the job.
    Dec 2008
    Ontario Canada
    The way most furnace blowers are set up, getting the blower to slide out the back would be quite difficult
    It's tough without pics, but could you cut a section of duct and re-fit so it could be taken in and out with relative ease in the future?
    Post pics on WOS?
    Virginia
    I did one this summer , same scenereo , no room to get blower out .
    I just looosened blower assembly ,let it fall into the bottom of cabinet , then layed on my side and reached inside cabinet to work to remove motor.
    What a pain in the ass that was
    s chester county,pa
    send duct designer/installer to replace fan and do duct mods.
    then fire said individuals.
    that would be too easy i guess. how about a modular blower assembly flipped on the outlet side of the ahu? if it would be service accessible. sometimes you gotta think out of the box.
    Oct 2012
    Thanks all. I'll try to get some pictures today.
    No thoughts on making a 10x6 access hole in the back of the cabinet so I can reach the collar on the blower motor?
    just cut the duct out of the way
    if it's easy access to back side for set screw hole- knock your self out.
    but:
    1-crap like that should have never been installed
    2-apparently the "codes" there don't cover or define easy access
    3-find what ever butt head put that in and try to beat some understanding into them
    Jun 2001
    Normally when you see crap like this its when the lowest bidder got the job. You get called out because the customer got a disconnected message when they tried to call the original installer back..
    Houston,Tx.
    Quote Originally Posted by Snapperhead View Post
    How do you do this when the blower assembly is on a rail/slide in type? It has one direction, slides out the front, not back, not down, and of course not up.
    Oct 2002
    Plano, TX
    No reason not to cut access hole in cabinet, if you want. Won't hurt.
    Often wonder why there is no hand hole access to blowers using new electronic ECM motors. Had to change just the electronc s mounted at the end of the motor. Why should it take 30 minutes to pull a blower just to troubleshoot when you could reach in the access hole and be done in 5 minutes.
    Jul 2000
    Northern Wisconsin
    Quote Originally Posted by timjimbob View Post
    If I have a choice of which side I bring the return air into it's always to the motor side. There goes the factory hand hole access.
    I'll take having to remove a blower assembly any day compared to how hard it is to get to some of the old ignitors and how many (were installed with no thought about having to be removed) items had to be moved just to get my hand near it.
    Eugene, Oregon
    Just remove the duct. It's usually not as difficult as you might think. Bite the bullet and "getter done"!
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Aug 2012
    MN
    Cut duct and reinstall with canvas peice to make quick work next time
