Results 14 to 19 of 19
    Dec 2010
    They appear to be 10" OD flex pipes. That's about 1,000 cfm, (flex is more restrictive to the airflow) or 600 cfm short. Based on the blowers capabilities, 1,600 cfm of return air (at .08 static) is desired.
    Dec 2010
    Quote Originally Posted by 545GAlady View Post
    Did I ever mention that the air rushing through the returns are sort of noisy?
    That could be a sign of restriction.
    Sep 2012
    Thanks for the information. I'll measure to make sure sometime. We do plan to replace the furnace next winter and we want to downsize, but since the heat pump is 3.5 tons, we'll still have to have a furnace with a 4 ton blower installed. Hopefully we can find a GOOD company to install the furnace and redo the ductwork as necessary. I don't think the company who installed the heat pump did a manual j. The old A/C was a 3.5 ton as well.
    Sep 2012
    Quote Originally Posted by George2 View Post
    Probably so. You can't hear the noise unless you are standing right in front of the grilles.
    Dec 2010
    I re-read this post.........I meant to say 10" ID (inside dimension). Sorry.
    Sep 2012
    That's okay. I knew what you meant anyways.
Comfortech Show Promo Image
Comfortech365 Virtual Event
