    Dec 2012
    Air-source Heat-pump question
    I recently purchased a townhouse with an air-source heat-pump and have 3 main questions. The unit is 22 yrs old (same age as the house).
    1) Now that the cold weather has set in (since +/- November...I live in Montreal), it seems to go through the "defrost" cycle frequently. The first time I heard the valve release "hissing" noise and saw steam come off the outdoor unit, I thought it was blown but now realize it's normal. But how often is "normal" for the unit to go through that cycle each day? Every time the unit turns on/off?
    2) The house also has an electric furnace, which is the "aux" source on the thermostat. During winter months, should I switch it to run off of the furnace instead of the heat-pump? (Note that in Montreal/Quebec, electricity is the main energy source because it is inexpensive).
    3) Is there a limit to the coldest outdoor temperatures where a heat-pump will still be effective? I have noticed since the weather got colder that the air coming out of the registers is never really warm. Is this a physical limit of a heat-pump or just that my unit is old and dying? (I also recently suspect a duct issue in one particular spot but to be investigated)
    4) What are the main regular maintenance items that I need to plan for? (I am a capable handyman but interested to know what I can do myself or if pros are needed)
    Thanks in advance. I appreciate any insights as I am new to heat-pumps.
    James
    1- there should be a defrost control to dictate interval, you may have an issue if it defrost "every time it comes on"
    2- that's always debatable, if electric rate is that low, 30 degree F (0c)
    3-do not ask an engineer that ??, yes there is a point that the HP is upside down_power consumption vs heat out put ( not to mention unnecessary wear & tear
    4- the air filter is the only thing homeowner friendly, regardless of haw handy you may be
    Dec 2012
    steve_mtl
    south louisiana
    using electric strip is an expensive use of electricity.
    what is your rate?
    I'm .08 cents per Kwh, and wouldn't ever heat with
    the heat strips. staged them so that only half would
    operate at a time.
    20+ year old heat pump is a long long life.
    planning on replacement in the next couple of years?
    start doing your homework now while you have the
    luxury of time to do so.
    your heat pump is probably about 8 SEER a/c & hspf of about 5.5
    compared to minimum 13 SEER hspf 7.5
    upgrading to that heat pump sweet spot between 15-17 SEER with hspf .85+
    is a decent savings for the upcharge.
    I agree that changing the filter is very do-able..LOL!
    lots of folks buy spray cleaner for coils..but have your
    hvac guy show you how and recommend a cleaner for you.
    you could do some minor duct sealing with paint on mastics
    or mastic tapes.foil & duct tapes fail quickly and are not worth the
    effort.
    any mechanical stuff..leave it alone.
    we make good money off handyman diy. seriously.
    best of luck
