Results 1 to 8 of 8
Thread: Attic ductwork
    Aug 2011
    Attic ductwork
    Hi: I'm trying to size a new upflow heater to existing non insulated sheetmetal system in attic. The old heater was removed from storm Sandy. I used a online calulater and got 49000 BTUS. There was no consideration for attic ductwork.
    Its only a 1000sf house and owner does'nt want to insulate ducts. Anyone know the addition heat loss from above ducts.
    thanks...
    Jun 2007
    Greenwood Indiana (Indianapolis)
    As much as 70% loss/gain, especially if its the return duct. Don't forget the ducts will sweat in hot attic this summer time.
    As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
    Are you sure the duct work in the attic isn't insulated. it my be that its just the sheet metal in the utility room isn't insulated.
    Jun 2000
    N. W., IN
    The owner may not want the duct insulated but that makes him wrong as you would be if you do the install that way.
    Dec 2012
    oklahoma
    might want to check your local codes . ductwork run in an unconditioned space isnt up to code around here.
    Cincinnati, Oh
    Quote Originally Posted by deadeye52 View Post
    thanks...
    If he doesn't want to insulate, then he better be spray foaming the roof line.
    Otherwise you have a lawsuit when the drywall repair/mold abatement issues come about.
    "Just get it done son."
    Dad adjusted
    Jun 2001
    I'd turn the job down if he doesn't want to do it right. Do you really want to oversize the furnace to accommodate uninsulated ductwork?
    south louisiana
    sounds like the owner is not understanding why ducts are insulated.
    do you really want to do a job where occupants will never be comfortable?
    high utility bills, dripping ducts & no comfort?
    there will be alot of call backs on this kind of job.
    have to agree with ron:
    I'd walk away if I couldn't get the homeowner to understand.
    are you sure the duct isn't internally insulated??
    best of luck.
