Results 1 to 7 of 7
    Oct 2009
    Raleigh, NC
    Semi-Hermetic Ice Ball
    Never seen a refrigeration compressor this iced up.
    Jul 2001
    Gold Coast of Connecticut
    Wow..............thats some low superheat. The rear bearing was surely taking a beating.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Sep 2010
    miami,fl.
    Quote Originally Posted by MicahWes View Post
    wow i never seen that before. that thing must have been running non sop for some time, what was the issue?
    Oct 2009
    Raleigh, NC
    Defrost failure. You should have seen the low-profile type unit cooler in the freezer.
    Mar 2009
    Mid-Mo
    That is amazing. I haven't seen ice that far back thru the motor. I've ran a ton of ice on compressor calls but good grief.
    Nov 2012
    NYC
    why would the rear bearing be effected?
    Oct 2009
    Raleigh, NC
    Oil washout.
