Results 66 to 78 of 167
12-31-2012, 10:33 AM #66
- Jun 2001
- Moore, Oklahoma
- 2,596
12-31-2012, 10:35 AM #67
- Jun 2001
- Moore, Oklahoma
- 2,596
12-31-2012, 10:40 AM #68
12-31-2012, 10:57 AM #69
- Jun 2001
- Moore, Oklahoma
- 2,596
Furnaces can still "work" even though they are shutting off on high limit. They run for a few minutes, go off on limit while the blower continues to run and blow hot air into the house. Once the furnace cools it resets and runs again. As long as it's not being used near capacity a homeowner may not notice this behavior, especially if the blower doesn't completely cycle off each time.
Pre-90's furnaces like you were talking about earlier that just cut the voltage from the gas valve while keeping the blower running would just keep working as far as he homeowner knew, unless they were hearing/watching the burners cycle.
12-31-2012, 11:25 AM #70
12-31-2012, 11:34 AM #71
- Jun 2001
- Moore, Oklahoma
- 2,596
12-31-2012, 11:38 AM #72
12-31-2012, 11:57 AM #73
Also, for any house that size that requires that little heat, just how much cooling is required. If that house is in an area far enough south to not need the least amount of heat that is available in a gas furnace, then a heat pump system would be the way to go, like is done in other Southern areas.
Since reg is refusing to give us specifics about the applications he is claiming, we have nothing to go on in order to find out why he has so many more issues than anyone else in the country.Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
12-31-2012, 12:03 PM #74Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
12-31-2012, 12:06 PM #75
This is all indicative of an improperly sized duct system, air blockage such as dirty filter or coil, loss of blower capacity etc. None of this has anything to do with the furnace being oversized.
What is the point of all of this rambling of yours? What are you trying to get at?Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
12-31-2012, 12:08 PM #76
12-31-2012, 12:29 PM #77
You know it's one thing to want to learn the trade, and just humble yourself and sit back and watch and listen, but when your argument is not fact, and you don't just stop for a moment to research something before you post, you not going to appear to be the brightest bulb in the house. It's like me going on a TV repair forum and and telling all the pro's there how a TV works or is wired.
12-31-2012, 04:07 PM #78
