Results 1 to 9 of 9
12-25-2012, 12:11 AM #1
- Sep 2012
- GA
- 306
Question about aux heat in basement system
I have a quick question regarding our basement system.
The thermostat for our basement system is wanting to run the auxiliary heat every time we run the temperature up 1 degree. Is this normal? Could it be the thermostat? We have been wondering since our electric bills have been higher than this time last year. Thank you in advance.
12-25-2012, 05:28 AM #2
Professional Member*
- Nov 2004
- SW FL
- 5,274
Check the AUX HEAT range setting options in the thermostat manual.
DON'T USE SET-BACKS ( or VERY rarely).Designer Dan
12-25-2012, 05:32 AM #3
Post brand and model number of thermostat. Were you operating the thermostat the same way last year at this time.
12-25-2012, 08:30 AM #4
Most stats do, especially Honeywell. That's why it is best with a pump to leave the same temp constantly. Or let the stat change the temp, it will TRY to limit backup but often can't.
12-25-2012, 12:31 PM #5
- Sep 2012
- GA
- 306
12-25-2012, 12:33 PM #6
- Sep 2012
- GA
- 306
12-25-2012, 12:36 PM #7
- Sep 2012
- GA
- 306
12-25-2012, 05:32 PM #8
- Nov 2004
- SW FL
- 5,274
Designer Dan
12-27-2012, 10:02 AM #9
- Sep 2012
- GA
- 306
