Results 1 to 13 of 26
Thread: Weekend challenge - fun time
12-23-2012, 09:24 PM #1
- Sep 2011
- 50
Here is the scenario.... you have to make this boiler modulate and purge (to at least 100 degrees or less)for under $.
The boiler pictured has a cold start control from the factory. GO!
You can use anything you want and modify anything you want as long as you stay at or below $. wholesale in parts.
(if this isnt allowed please delete)
12-23-2012, 09:52 PM #2
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
are you asking what is needed to accomplish your task?
if so; you may be pushing the envelope of this open forum.
12-23-2012, 09:56 PM #3
- Sep 2011
- 50
12-23-2012, 11:01 PM #4
- Sep 2011
- 50
49 views and still nothing?. I assume that you are checking it twice and seeing what is naughty or nice?.
12-23-2012, 11:54 PM #5
- Apr 2003
- Maple Grove, MN
- 723
Call somebody else
Seriously though, what do you mean by modulate and purge? Are you talking about a primary/secondary setup where the primary maintains a steady temperature while the secondary modulates somehow? Does purge mean an auto air vent? Is labor and piping materials included in your price? Does everything have to be automatic, or can we have some guy stand there operating manual "modulate" and "purge" valves?
12-23-2012, 11:57 PM #6
12-24-2012, 12:11 AM #7
Place someone next to the boiler with his/her hand on the on/off switch and a thermometer & turn it on. When the thing, whatever your are measuring) reaches 110 degrees have that person turn off the on/off switch.
- Alexis de Toqueville, 1835
12-24-2012, 12:59 AM #8
- Sep 2011
- 50
LOL!~I scared the cat half to death with the snarf I made when I read this
Beer all over the floor...which I have to clean up now
Modulate the out going water at a set temp (lets say whatever you like between 140 and 180) and then purging the remaining water out of the boiler after the call is satisfied.
Reason for doing this is to bring the boiler to temp fast without chilling the element or causing the boiler to shock and then getting all the water top side after the stat is satisfied, rather than losing it to standby.
Material only
12-24-2012, 01:01 AM #9
- Sep 2011
- 50
The rest of you are just as funny... HAHAHA
12-24-2012, 05:50 AM #10
Weil McLain BCP 3. Its simple fast and easy.
It will run the circ anytime the outdoor temp is below the heating point, and regulate boiler temp based on outdoor temp.
Won't bring the water temp up fast, as what purging the boiler is counter productive to doing that.
12-24-2012, 09:02 AM #11
I'm thinking of various ways but I'm not getting the question completely. A Teckmar could keep a set temp plus with ODR modulate the temp. A bypass would let the boiler heat fast also.
12-24-2012, 09:14 AM #12
Ok 60sec go , you need three stats , a bypass ,holding take and a solenoid. When a boiler is turned off some heat remains in the mass of the boiler. If the flow through the boiler is stopped at the same time the boiler is shut off, the residual heat is lost. Therefore, after operation of the boiler the residual heat in the boiler should be purged to the system in order to decrease standby losses. This is accomplished by turning the boiler off but keeping the system pump on for a period of time. This function increases system efficiency by minimizing standby losses.To ensure that the DHW tank is up to temperature after the DHW Setback period the control must raise the tank temperature before the setback period ends. This can be accomplished automatically by using a control that has an optimum start / stop function. This function increases comfort by ensuring the DHW tank is up to temperature at the beginning of the occupied period.DHW priority allows the DHW tank to recover faster by temporarily suspending the heat supply to the heating system. All of the available heat is provided to the DHW tank for a period of time. This function provides more comfort by ensuring faster DHW pick up times and increases system efficiency by often allowing the use of a smaller heat source. OK what did I win....???? lol
12-24-2012, 09:38 AM #13
- Sep 2011
- 50
