Results 1 to 8 of 8
    Dec 2012
    Carrier Infinity heat pump makes terrible noise when heating
    Hi there! I have a Carrier Infinity heat pump - Model # says 38YDB048. It's about 7 years old now. I've had it checked out and it's always passed with flying colors. No one sees anything wrong with it when called out.
    However, it makes an absolutely horrible sound many times when it's in heat pump mode - so loud that it wakes people up including the neighbors. Sounds like metal on metal screeching - like if Godzilla had metal hands scratching a metal chalkboard.
    When looking at it - it's seems it seems to be functioning fine even while it's making that terrible sound. I've shoved it a couple times, which sometimes seems to help? I don't know...probably bad to do that...
    One thing, it does NOT make that sound while cooling, only when heating. It's been doing this for a couple of years now and again, when someone is called out, it either doesn't make the sound or it checks out perfectly fine.
    I'd rather not keep spending money on someone to tell me it's working but the horrible sound it makes is embarrassing and scary.
    Ideas?
    Aug 2008
    Booneville, Mississippi, United States
    Its in defrost, call a tech and have him test it in defrost mode to simulate the noise. Then he can decide if its a unit issue or normal defrost.
    Dec 2012
    Thanks! Tho, as I've said, I've had at least two people come out here to look at it and it always checks out. Is it "normal" for a heat pump to sound like an aircraft crashing even if it's functioning properly?
    Aug 2008
    Yes it can make a lot of noise during defrost. The outdoor fan doesnt run and only the compressor will till it satisfies coil temp or defrost time depending on unit.
    Mar 2012
    Additional infractions may result in loss of posting privileges.
    Dec 2012
    Ok - I guess I'll spend that $100 on sleeping pills for the neighbors then.
    Aug 2008
    You can ask your contractor about a sound jacket for that compressor, will help the noise.
    imatine
