Results 27 to 39 of 39
01-27-2013, 03:05 AM #27America; first we fight for our freedom,
then we make laws to take it away.
-Alfred E Newman
01-27-2013, 03:26 AM #28
those cheap supco's are just that. I would use a refrigeration style "real" ranco style head pressure control. But in this case, the ecm motor is a concern.
Increasing the heat load outside may take some creativity, sounds like your guy/customer is pretty smart. Anyway you could arrange for him to partially block the condenser during low ambient times? Just a thought.......
01-27-2013, 11:34 AM #29
Professional Member*
- Mar 2001
- 1,409
Call York tech support. They 've always been very helpful to me. Used to be a guy there named Smed that was sharp as a tack. I'm sure he's since retired, and probably dead. Neat guy and was full of information.
One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
01-27-2013, 04:49 PM #30
What I need is a head pressure control that completely cuts voltage to the fan rather than try to modulate it. The customer has already started blocking the fan somewhat but I fear the motor will fail before long... Does anyone know of a kit that completely shuts the fan off?
-Alfred E Newman
01-27-2013, 04:51 PM #31America; first we fight for our freedom,
-Alfred E Newman
01-27-2013, 10:13 PM #32
There should be unused low voltage leads to the ECM. Try looking into the wiring configuration when a reheat coil is used.
I have to go back and look, but I know there is a way to drop the speed with the inputs. Maybe two inputs are used and you cut one of them??
Again, I will have to dig up the manual I am thinking of to be sure."The only true wisdom is in knowing you know nothing" Socrates
01-28-2013, 07:17 AM #33
- Feb 2009
- Tallahassee, FL
- 4,705
There is ususally two 24v control signal wires like a x13 but only two speeds.
01-28-2013, 08:20 PM #34
- Jan 2010
- 4,437
Get us the full model number for the unit and let rundawg post the wiring diagram. With that I am sure we can help with your problem.
02-01-2013, 01:42 PM #35
I'd switch the 24v control signal to the motor, switching the 240v will fry switches, possibly even the module.
Unplug one while it is running and you will see what I mean.
If it has a Genteq/Regal-Beloit motor on it, a creative electronics person could use a PWM signal to control the fan speed.
I'm not aware of any off the shelf control that us less creative people can buy though.If more government is the answer, then it's a really stupid question.
02-02-2013, 02:04 AM #36America; first we fight for our freedom,
-Alfred E Newman
02-02-2013, 07:44 AM #37
Wonder how a T991A would work. its a proportional control, 0 to 135 ohms.
02-02-2013, 08:26 AM #38
02-02-2013, 03:26 PM #39
- Jan 2010
- 4,437
How about that model number ?
