Results 14 to 25 of 25
Thread: Carrier RTU
    Nov 2009
    Bismarck ND
    Found belt broken causing y2 to call and bring on mechanical. Thinking about adding an outdoor lockout to stop mechanical cooling from coming on as the compressor were a huge block if ice
    Southeastern Pa
    Quote Originally Posted by HVACTECHND View Post
    Many units use a low pressure safety, too.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    NH
    Or a freeze stat.
    That is possible. A lot of guys have no interest in learning how an economizer works, or how to troubleshoot it.
    So true. Economizers have kept me very busy during the winter over the years. On many new accounts I often find enthalpy sensors disconnected with nothing else wrong. I tell young guys to learn about them because they generate work for the cold months when some get slow. I urge guys to not look at the controller and get overwhelmed. I tell them to break each circuit down and things get much less complicated. That is of course once they get an understanding of them
    Sent from my SGH-T999 using Tapatalk 2
    Quote Originally Posted by Dchappa21 View Post
    Or a freeze stat.
    That was my initial thought . .
    Southeastern Pa
    Or a freeze stat.
    Also a good idea to have that in the chain. We also install a low ambient control for those Y2 calls on cooler days.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2012
    Georgia
    Economizer would disable 1st stage mechanical cooling if outdoor conditions were suitable (sounds like they are) for free cooling. Suction line freeze stat on 2nd stage compressor or Low ambient thermostat for 2nd stage lockout. These units are not designed to protect the compressors from ANY unit malfunction.
    Last edited by Cold shot; 12-31-2012 at 06:15 PM. Reason: incorrectly described the product that was being talked about.
    Southeastern Pa
    I can't say that I know of any design that "protects the compressors from any unit malfunction....."
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2012
    Georgia
    True, but there are several things that can be added. Air proving switch, freeze stat, low & high pressure switches, discharge line thermostats, phase monitors. All to protect the compressor.
    Southeastern Pa
    Quote Originally Posted by Cold shot View Post
    I'll go with that. You can protect the compressors from SOME malfunctions.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    In a van by the river
    Just to prevent any confusion, when second stage cooling is energized while a system is economizing, first stage compressor energizes and comes on (compressor 1 and not compressor 2)
    ## + years in the field never made you a know-it-all This industry is far more diverse than you are
    Jan 2010
    I always shake my head when I see a economizer installed but never hooked up.
