Results 1 to 11 of 11
Thread: Carrier Issues
    Dec 2012
    Carrier Issues
    I noticed last night that it was getting very warm in my house so I went to mechanical room to discover the heat pump was running non stop. The line sets were very hot and the only way to shut it down is to turn off the breaker. As soon as breaker is turned back on the heat pump starts even if furnace is off. This is a 4.5 ton ten year old system with the variable speed blower and all the bells and whistles...any ideas??
    May 2009
    Cumming, GA
    Are you a homeowner? Sounds like it. There is no DIY advice here. From what your wrote, you have a pretty routine problem. Call a professional, he will be able to diagnosis your system and have you up and running in no time.
    Check our contractor locator map for someone in your area.
    Moved to AOP
    Tallahassee, FL
    4.5 ton?
    Dec 2012
    Fixed..contact.. $$$ part
    May 2009
    Cumming, GA
    Great to hear! Happy holidays.
    Dec 2012
    I do commercial sheet metal for a living but my knowledge in service is very little...I can fix the issue but I have no clue how to diagnose them..
    You should fill out your profile.
    Dec 2012
    For some reason I am having troubles doing that..I am blocked from my profile..but I can post..I will mess with this more in the morning and see if I can add more info
    according to rumor control-you have to have 7 post to fill profile out.
    Dec 2012
    Ok..thanks for the info..I was wondering what was up
