Results 1 to 13 of 20
    New York City
    Belimo or T.A.C. actuator that uses this type Of Coupling Puictured
    Hello:
    What number in the Belimo Actuator Part Number
    Will specify the Type of direct coupling pictured in the
    We are operating over 45 Belimo valves and
    the Actuator must have
    The same type of coupling pictured in the
    above Attachments
    What type of Direct Coupling is this called
    I need to reorder
    24 Volt A.C.
    Manual Override
    Spring Return
    133 Lb Torque
    2-10 V.D.C. control signal
    Thank you
Size:  41.1 KBName:  Coupling Coupling Ac5.jpg
Size:  37.5 KBName:  Coupling Ac3.jpg
    Ontario Canada
    You can download the PDF of Belimo parts and match up what you think you need. You could also call Beilmo, they are popular.
    D.
    Quote Originally Posted by techservices View Post
    Hello:
    above Attachments
    I need to reorder
    24 Volt A.C.
    Manual Override
    Spring Return
    133 Lb Torque
    Thank you
    A=133 in-lb, F= spring return, 24=24 vac/dc, SR=2-10vdc
    Per the nomenclature I'm looking at but I could be way off. I've been trying to learn more about these for personal knowledge and ease in ordering. There are so many lol. The pdf have is 400+ pages. If you can't find it I can email it to you.
    Sent from my SGH-T999 using Tapatalk 2
    Dec 2012
    Good afternoon,
    I can help with any questions -
    The product you are referring to is an AFB24-SR
    Please contact me with any questions
    Dec 2012
    As a reference I work for belimo -
    Riffdav what is the "B"?
    Dec 2012
    We have a "b" for basic and a "x" for customized...( longer whip etc)
    Oh ok. Thank you
    Jun 2006
    New Jersey
    Quote Originally Posted by Riffdav View Post
    Good afternoon,
    Don't you still need an adapter, due to the shorter length of the actuator? Also, what about the connection the OP pictured........I don't see a V clamp in the OP picture?
    Dec 2012
    Depending on the application and valve these are on yes there will be a potential linkage.
    Please call 1-800-543-9038 and a belimo rep can determine based on the application which linkage is needed.
    Dec 2012
    SR is spring return
    njfranco
    Dec 2012
    Columbus OH
    I think Belimo is the best ive used very easy to work with.
    Quote Originally Posted by njfranco View Post
    SR is spring return
    njfranco
    F = spring return ... the SR is the control. With SR being 2-10vdc
