Results 1 to 8 of 8
    Central NJ Area
    Lennox Pulse Flapper Valve
    Does anyone know where i can get the Flapper valve for a Pulse 21 furnace? I know parts directly from Lennox are not available, but wanted to see if anyone knew if a after market Flapper is available
    Also, if anyone knew where i could get a spark plug for it? Is their a motor vehicle or motorcycle spark plug that could be uses? Flame sensor as well
    Thanks!
    PS- Does anyone have a pulse Pulse heat exchanger pressure test tool they want to part with or know if i could still aquire one of those?
    May 2012
    Upper Michigan
    The tool can easily be made its less of a tool and more of a kit of plugs and a gauge. I don't know if you can get parts anymore but I just pulled a pulse with all the parts you seek. Plus we have new stuff. If you had a spare gas flapper you could make the tool. I could take a pic of it tomorrow.
    Central NJ Area
    Quote Originally Posted by Joehvac25 View Post
    I'd appreciate it.
    May 2012
    Upper Michigan
    Click image for larger version.
ID:	339291Click image for larger version.
ID:	339301Click image for larger version.
ID:	339311Click image for larger version.
    redlands, ca
    Champion CJ8 spark plug from your local auto parts store will work. Gap at .105 about a 45 degree angle. Flapper material is still available. Ensure condensate drain is clean and draining. It's best though to pressure test the heat exchanger first and also inspect the welds on the manifold of the secondary heat exchanger.
    May 2012
    Upper Michigan
    If you have an emergency and need parts I can get all those and new or used.
    Central NJ Area
    Thanks! I just found a flapper valve. I'm assuming that is the issue. When i bang on the housing it starts to fire and if i bang on it again it stops. I'm just going to replace it until they can have the unit replaced/
    May 2012
    Upper Michigan
    Quote Originally Posted by Nytefog View Post
    Ok, getting someone heat is the main thing. Tell them to get a good co detector.
