Results 1 to 11 of 11
Thread: Reach in cooler
    Houston,MS
    Reach in cooler
    Had a reach in cooler given to me that was not working ,compressor would not start , the person that gave it to me said that a friend of theirs gave them a replacement compressor and let me have it also, it was correct one so I changed it and replaced filter dryer ,now when the thing cranks it will only run about 30 to 45 seconds and kicks out on overload, pressure on the low side seems to be okay, no tap for head pressure but discharge line doesn't seem too terribly hot to touch.. Just wondering if anyone else could maybe point me in the right direction as to my next move... Any advice would be appreciated!
    Dec 2000
    Flat Rock, NC
    check your wiring at compressor sounds like start winding is staying in.
    Virginia
    you definately shouldnt be able to hold onto that line ..hmm
    so did you weigh in the refrig , or just wing it
    Jul 2012
    Everett, WA
    Quote Originally Posted by airpro71 View Post
    What drier did you use? When I replace them on cap tube systems, I used c-032-cap-t driers that have a port on them. It sounds like you have a restriction in the cap tube.
    Virginia
    a free refrigerator ..... you can pretty much count on cap tubes clogged
    Nov 2009
    Richmond, working under tarps
    I wouldn't call someone a friend, if they gave me some of their junk.
    Aug 2012
    willowick ,oh
    So you changed the compressor and plugged all of the original start components on it. Nice work. Atta boy. When I need to do a comp on a reaching. It also always gets new components drier and the oem size cap. Don't rely on the idiots before you. Assume the worst and it will help in the end
    NH
    If cap tube was clogged, than your low side would go in vacuum. Check your start components, probably ptc is bad.
    Phoenix,AZ
    Quote Originally Posted by zibby View Post
    Not if he stuffed 2 lbs of 134 in a 7 ounce sack!!!!
    NH
    Quote Originally Posted by KB Cool View Post
    True
