Results 1 to 13 of 22
    Dec 2012
    Sagamore Hills, OH 44067
    Gas furnace size recommendation- Model J attached.
    Hello again,
    Spent some time with HVAC-Calc, a tape measure and the house to do a Model J. Took some time, but not all that difficult. It's an educational experience for sure.
    Attached is the report which is pretty accurate...I hope. We plan on replacing windows within the next year, but didn't include them. They can only make the house 'tighter', I suppose. If anyone would care to help us out and give a size recommendation, we'd sure appreciate it. If there's anything that looks out of line, please let me know.
    Thank you in advance,
    Steve
    House Manual J Detail_12-20 Final.pdf
    Dec 2012
    Just an added note, we're going with a Rheem RGRM (90+%) furnace and one of their AC units.
    Athens, Ohio
    I cannot open your link for the pdf file.
    Re. the windows, I suggest you make a copy of the job and change the windows on the copy to see what effect they have on the load.
    You may want to add your location to the post or put it in your profile. That will have an impact on the sizing.
    My vote is RGRM-06 with 2.5 ton A/C. Prefer the good ones to the value cubes if budget permits.
    Jun 2001
    My house is the same size and can keep 75f inside with it 100 outside on a 2 ton AC. Manual J calls for 2 ton, don't oversize for the 3 days per year that it's over 88F.. Put some shades on the windows and drop another 1/2 ton in cooling load. Close shades on days when it's near design temps outside.
    I'd think strongly about some type of zoning/manual dampers that you can adjust seasonally. Otherwise the top floor will always be hot and the bottom floor cold. With 3 floors correct ductwork is CRITICAL to having even comfort through the home. Much more so than getting high end equipment. Don't drop 5 figures on a HVAC system then not be comfortable. I'd rather have a base 80% furnace with a 13 SEER A/C and nice zone control system than a 95% furnace/18 SEER A/C with poor ductwork design.
    Not only will the comfort be better, but your utility bills will be lower since you won't be overheating/overcooling one floor to make the others comfortable. Without zoning or multiple systems that's what typically happens in multi floor homes. Overheating/cooling floors will cost you WAY more than the 15% you save in gas by going to a 95% furnace.
    Dec 2012
    Well, I can't access my profile or attachments due to account restrictions. Maybe the message will help?
    GobyOneGnoby, you do not have permission to access this page. This could be due to one of several reasons:
    1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
    We're in NE Ohio or zip code 44067. As for the ducts, they are what they are as it's a 50 year old house with most of the duct work inaccessible. Sorry, forgot to mention these are replacement units.
    I'll try attaching the report again, but here's the report summary just in case.
    Design Conditions: Cleveland
    Summer temperature: 73 Indoors, 88 Outdoors
    Winter temperature: 68 Indoors, 5 Outdoors
    Relative humidity: 50
    Summer grains of moisture: 94
    Daily temperature range: Medium
    Sensible Heat Gain 23,430 BTU/H
    Latent Heat Gain: 2,111 BTU/H
    Total Heat Gain: 25,541
    Total Heat Loss: 50,880
    Windows would reduce heat loss another 2,000 BTU/H and reduce total heat gain by almost 1,000 BTU/H.
    Jun 2001
    2 ton AC and 60K furnace by your calculations...
    60k just seems like a LOT of heat for 1,600sqft...
    What size do you have now and how well do they heat/cool?
    SW FL
    Calculation seems Reasonable with the care you took to match your house.
    One might say heat load could be Slightly high.
    Infiltration is always the questionable variable.
    0.84 ACH winter is a fit for 50 year old house.
    2.5 ton Heat Pump with modulating furnace with switchover about 35'F.
    I would compare / review BRYANT products.
    Designer Dan
    Jun 2001
    Why the 1/2 ton oversize by everybody?
    Northeast Ohio
    His location along with his Man J calcs would get a 2.5 vote from me as well. Being in the area I feel that the design temp is low from past experience.
    DEM
    His heat gain is 25,500 as is. The 13AJN, for example, is 23,000 BTU. I never liked cutting thing close. Have company over or do some extra cooling on a 90 degree day and it gets a bit warm in there. If he does good windows and drops his gain a bit and doesn't mind cutting it close, great. I just didn't want to risk customer complaints.
    Dec 2012
    Quote Originally Posted by 54regcab View Post
    The furnace is an 80% 100K and the AC is a 3 ton. Both are 16 year old Goodman units, but they keep the house comfortable even in the coldest/hottest days. We've done a lot to the house to improve things (doors, some window and insulation), but they seem to be overkill at least for how the house stands now.
    Northeast Ohio
    I would be comfortable going with the 60,000 furnace for your area given the age of your home and size unless there are extreme exposure issues. The wind does blow hard in the lake area.
    DEM
