Results 1 to 13 of 25
    Apr 2011
    Klein, Texas
    Aquasnap Chiller with micro channel condenser coils
    Anyone know if the aquasnap condenser coils have a top/bottom direction? I had a crew change out a set for me and now only the closest side to the inlet outlet seem to get flow. From left to right the right side stays cold and from top to bottom the top two third is warm while the bottom third sweats cold. These are brand new coils from the factory. The chiller maintains a 425 head until the last compressor kicks on and she shoots up to 600psi and goes off on a pressure fault. I weighed in the 86 lbs 410a and pulled the vacuum before. I'm thinking the coils must be in upside down?
    Atoka, TN
    Model Serial Number ?
    Apr 2011
    Klein, Texas
    Quote Originally Posted by cri3541 View Post
    It's a 30rb not there right now had to drop down off the roof 60 mph gusts all day. Will get that info and respond in a bit.
    Atoka, TN
    I am looking at a 60 ton and Discharge is on the inside of V and Liquid Line on the outside. Does that make sense?
    Feb 2012
    utah
    I think you would have to try hard to get that in backwards as they weld up exactly like they come out. sounds like during the changeout things got dirty, maybe bad piping practices. they are super easy to plug so hopefully they were using nitrogen.
    Apr 2011
    Klein, Texas
    These coils are 3 pass and bolted in
    Apr 2011
    Klein, Texas
    The coils we were given by carrier to replace leaking flange gaskets. I'm thinking that the coils must have a directional flow and if they were put in upside down the flow would be interrupted or impeded somewhat. Yes a lot of nitrogen was used, we contracted seven chiller coil change outs. I wasn't there for the changing part but did the start ups.
    Apr 2011
    Klein, Texas
    Here it is: 30RBA1604-53-97
    0508Q85367
    East of big city prices.
    So your a east coast tech in Houston?
    Harris county?
    Quote Originally Posted by Eastcoasttech View Post
    0508Q85367
    Apr 2011
    Klein, Texas
    Quote Originally Posted by Dallas Duster View Post
    Harris county?
    I could answer that depending if I owe you any money? Lol yes harris county.
    The bottom of the coil should have a horizontal run of aluminum that is not connected to the header. Still trying to understand the sweating part of you explanation.
    Apr 2011
    Klein, Texas
    Okay there are three points where the header attaches. Top middle and bottom. The two top most flanges are abnormally hot. The bottom most "suction" one was cold and sweating like it was a suction line. I'm going to check in the morning for that aluminum horizontal line.
    So all 3 are sweating?
