Results 1 to 13 of 17
    Dec 2012
    Smelly combustion exhaust gas
    I have a Trane 5 ton rooftop that emits a strong odor from the combustion blower. The unit is about 2 years old. There is no combustion air restriction and the manifold pressure is correct. Anybody ever experience this problem?
    Southeastern Pa
    Not so much on a Trane RTU, but it is usually indicative of a combustion issue that must be discovered and corrected.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Howell, Michigan
    Get your Testo out and combustion test it. Amazing what you can find sometimes, even on a new unit.
    Jul 2009
    Columbia, MD
    Quote Originally Posted by HeyBob View Post
    Amen.
    I use my analyzer on every unit.
    Nov 2008
    baltimore
    Without a combustion test how can we help you? Check gas pressure inlet and outlet verify what nameplate calls for. The analzyer will give you o2, co,co2, efficency as well other things depending on model. Get back to us with those numbers and someone should be able to give you a place to start.
    One thing I never got in deep with is combustion analysis. I've decided I need to really get heavier into this. Any of you guys have good links to informative reading and recommendations on what type of combustion analyzer to get?
    Sent from my SGH-T999 using Tapatalk 2
    May 2002
    There was a local guy that died from co poisoning,,,,while working on a roof top... I wouldn't breathe to much of that until you test it
    mikeacman
    Southeastern Pa
    Do you have a link to that news story?
    May 2002
    not sure it made the news ,,,one of my coworkers brother in law was the victim in the neighboring county....osha is involved. As well a bunch of lawyers
    I'll talk to him and see what I can dig up ,,,happened last year ,,,
    mikeacman
    Southeastern Pa
    Quote Originally Posted by mikeacman View Post
    You mean in 2011?
    You can send me a PM with company name, etc, if you like. I want to look at the OSHA file.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    May 2002
    I believe it happened in Henderson KY BTW
    mikeacman
    May 2002
    Dec 2012
    I know I am getting too much combustion air. I don't know why. Just thought someone may have run across this situation before.
