    Sep 2012
    northern va area
    thermal block (gel)
    I'm still new the trade and recently started brazing. I was told reversing valve is one of the most difficult parts to replace when it comes to brazing. one of the reasons would be because the reversing valve can over heat while installing it. One tech mention thermal block helps. Also heard an old timer mention wraping the valve in a cold wet towel which makes sense. Just wanted to know if any one has used the gel or still uses it or what brands work better than others. Thanks for your help.
    Calgary, Alberta
    The gel works great.
    Jul 2009
    Columbia, MD
    Quote Originally Posted by syndicated View Post
    I agree with him ^^
    Also using the proper sized tip or oxy/acetylene with a good tip will narrow the chances of burning it up.
    sometimes cuttings and brazing the 3 pipes to the valve first then use couplings works the best.
    Sep 2012
    northern va area
    I never thought of that. thanks for the tip
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by gravity View Post
    I use this method all the time when working in ceilings
