Results 1 to 13 of 27
Thread: Oh man... Why?
    May 2011
    Western, KY
    Oh man... Why?
    This should not be allowed.
    This flue is below the roof line as well at the same place.
    Jul 2009
    Columbia, MD
    It's expensive to service them. Need a lift.
    Eugene, Oregon
    If the duct won't go to the equipment, the equipment will go to the duct.
    Seems like it would have been less expensive to set the equipment on the ground and run the duct up the wall than build stands for the equipment. They must have had other reasons to put the equipment up on stands. Flood zone perhaps.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Central VA
    Quote Originally Posted by air1 View Post
    Maybe they didn't want to worry about copper thiefs
    Apr 2011
    Coastal Maine
    This is stupid. The explanation that I hear from the train drivers, every time they do this, is that the fan in the package unit won't support the extra vertical lift and still maintain the required static pressure. Whatever....
    If that is the case, then they need to chose the right equipment for the job.
    Aug 2009
    Beatrice, NE
    Just bring in a front end loader and about a dozen semi loads of dirt. OR ... you could just tell the customer that those units are in a un safe condition and need a proper deck and rail around them to be properly serviced. I beleave code actually requires that.
    dealt with a few like that; stupidest thing I've seen.
    write it up as unsafe to service.
    Jun 2011
    Houston area
    For those of you familiar with Kemah, TX. I worked on these two a few years ago. Pretty common around here. I'd guess about 50% of the houses have access ladders.
    I wouldn't have worked on those packages but then again I'm selective.
Size:  63.4 KBName:  092411_1503[00].jpg
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    Dec 2008
    Buffalo NY
    I would rent a platform lift and charge it to them. No way would I try to do that work off of a ladder.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Tallahassee, FL
    Good theft deterrent
    Apr 2010
    Magnolia, Tx
    Quote Originally Posted by SBKold View Post
    I disagree, they just have to cut one leg to drop the whole thing.
    May 2011
    Western, KY
    I replaced the inducer off the ladder, not real excited about it but it was on the front, another unit has a blower out and I'm pushing strongly for us to use a lift for that.
    Dec 2008
    Buffalo NY
    Quote Originally Posted by mason View Post
    I would only do that off the lift. You would have to crawl in there off a ladder.
