Results 1 to 13 of 21
    Aug 2011
    Northern VA
    Confused What to use to braze copper to stainless steel?
    Hey guys. Anyone have suggestions on what brazing alloys will work for brazing copper tubing to 304 stainless fittings? This is a plate heat exchanger as an r134 evaporator. Thanks in advance.
    Oct 2011
    Chicagoland Area
    silver solder
    burlington county n.j.
    silver solder
    +1 the good stuff and the white paste flux.
    Quote Originally Posted by twophase View Post
    I just did a couple and used 45% with the Harris white paste.
    Mar 2009
    Mid-Mo
    Quote Originally Posted by jimp View Post
    I was thinking 45% coated rod.
    Jul 2010
    So-Cal
    The orange coated rod
    X2
    I use 50%flux coated rod
    And paste.
    The real trick is EVEN heat.
    I use a smith torch with the round tip.
    Quote Originally Posted by jackintheboxtec View Post
    Dec 2008
    New York, ny
    stay bright? with flux
    michigan
    56 percent silver and flux, does a great job, nice flow
    Aug 2011
    Northern VA
    silver solder
    So when you say silver solder, I assume it's different from the lead free plumbing solder? I know that's got a decent ammount of silver in it.
    I have a little bit of blue flux coated rod that looks like it's a pretty high silver content. Anyone know what that might be? I only have six 3/8 in. joints to make and those packs of high silver alloys are brutally expensive. If the silver plumbing solder will work, I'll probably just try that since it is just a personal project, long term reliability is not a major concern, and it's on the low pressure side. If not, I'll just have to cough up the $$$.
    I like to control the flux, and brush it on before I braze.
    NO 95/5 solder will NOT work!
    The blue rod will work.
    Orange better. 56% silver. 23% copper. Zinc and tin.
    You buy it by the rod
    You only need one!
    Oct 2011
    Chicagoland Area
    Safety Silv 45% . Plumbing solder will not work. Sears sells the coated rods the others are talking about. Any welding or gas supply store should have those also.
