    Feb 2012
    What does LTCO and BP mean?
    Hi,
    I know that LTCO is Low Temperature Cut Off and BP is Balance Point. But what excatly are they and what do they do with regards to a heat pump.
    The aux heat on my set up is controlled by the heat pump and not my thermostats. I have the LTCO as low as I can put it but the Aux heat is still coming on at about 1 deg C.
    Here's a pic I took of my heat pump control board. Can someone tell me if this is correct?
    Name:  Pump control board.jpg
    Virginia
    Additional infractions may result in loss of posting privileges.
    cfmstealer
    Virginia
    are you sure that the aux heat is not mis wired
    Go Trump
