Results 14 to 25 of 25
    Jun 2008
    In the Boondocks near Marion, IN
    Dupont's PT Calc is a good one to have on hand. FREE too.
    Feb 2011
    Orange County, in a Galaxy far far away...
    Bitzer refrigerant of pt chart, Dropbox for storing all those manuals and videos on equipment.
    PDF reader, to read those manuals on pesky equipment.
    Cam scanner, for scanning receipts and sending them back to the office for billing.
    Nov 2012
    Toronto
    I use the dupont PT calc and ibooks. PDF management is essential. Thats all I use my ipad for.. so my manuals don't take up all my cab space.
    Rochester, NY
    Bitzer PT app, Weather Channel, Converter+ for iPhone and sudoku.
    iBooks is great for manuals and PDFs
    My most used HVAC related app is HVAC Buddy, for target superheat and target evaporator temperature drop(aka Target Evaporator Exit Temperature).
    Quote Originally Posted by mcjo tech View Post
    If you are looking form a Superheat/Subcooling Calculator in its true version (a calculator) then mine may be what you are looking for.
    Search for ExactCharge Calculator 3.0 in iTunes.
    Back when I was using a PDA, I used ExactCharge all the time.
    I'd switch back to it from HVAC Buddy if you would add target evaporator exit temperature calculation to it...
    Jun 2006
    Mark
    I am going to be doing an update to include some newer refrigerants like MO99 and R427A later this year so may go ahead and add the TEET into the calculator at that time.
    My new HVAC Flat Rate App has been keeping me kinda busy during the last 6 months.
    Mark
    I brought it up in a couple of threads YEARS ago though.
    Jun 2006
    I know.
    I gave it a half a$$ed effort about 8 months ago. Tried to find or make a math formula for it but was unsuccessful.
    Seems we will need to input the chart and then pull averages out of it for 1 degree increments.
    Not unless someone has a formula for it and would like to share.
    I know it can be done though with the chart.
    Jun 2015
    Miami FL
    Quote Originally Posted by Buddy Lee View Post
    I'm using Bitzer, Carrier Enterprise and RTFM thermostats.
    Hi Buddy Lee, what is your take on the Carrier Enterprise App?
    Madison, WI/Cape Coral, FL
    I used the Ultra-Aire free app for estimating the amount of moisture being removed from a cooling coil.
    Plug in the temp/%RH and out, estimate the cfm provides lbs. per hour condensate. Will do the reverse or any missing part.
    Works with a/c, humidifier, or dehumidifier.
    Regards Teddy Bear
    Jan 2005
    Emerald Coast
    I use my Flirone app a lot.
    Is my Favorite.
    Do not attempt vast projects with
    half vast experience and ideas.
    May 2011
    clayton nc
    HVAC buddy is a great app. Needs refrigerants added though. Another app thats pricey but excellent in my opinion is HVAC Load calc bundle by carmel.
