Results 14 to 24 of 24
    Dec 2012
    I don't have the serial on me (I am at work) but it is a federal pacific...really old too. I posted pics of it on the garage journal
    Removed forum link to DIY page
    Philadelphia, PA
    The internal wiring is incorrect. The feed from the breaker panel is Very Dangerous. Shut it down and hire a professional before you burn your garage down.
    Aug 2012
    Whats with the blue track pipe, is he using that for conduit?
    Is the fan hooked to nuetral?
    Dec 2012
    Yes the Blue conduit is used to sheath the wires. Everything is how the landlord had it hooked up at his house before he switched to a different unit and gave this to me..one end of the 120v fan is hooked to neutral the other is currently disconnected. but it was hooked in with the red lead
    Aug 2012
    Time to give up the ghost.
    May 2012
    Upper Michigan
    Quote Originally Posted by toocoolforschool View Post
    It's smurf tube, a plastic flexible conduit.
    Aug 2012
    Quote Originally Posted by Joehvac25 View Post
    Okay thanks, smurf tube, I like it.
    May 2012
    Upper Michigan
    I have only seen it used once. Our sparky said it was popular for a short period of time and I'm guessing because its cheap!
    Aug 2012
    I get it a bright idea that nobody bought into.
    May 2012
    Upper Michigan
    I wonder if its against code?
    My bad.
    I thought that giving you a nod and a little hint buried in my post would be enough for a clever DIYer to catch it.
    You clearly need the attention of a professional to resolve this problem.
