Results 1 to 9 of 9
    New Boston, TX
    hey need some help, I have a york old faithful gas unit where the rollout limit had tripped, I had the call today, it has only done it one time so far, but I just changed the gas valve out 2 weeks ago, just didnt want to miss something, I am not a DIY'er, I am a contractor
    Feb 2005
    Central Alabama
    You will have to register to get help around here
    .....Sorry.........
    I'm not a bad guy just following the rules
    leland nc
    tripping on roll out 90 percent chance cracked heat exchanger
    east central indiana
    So after (I assume) you reset the rollout...then what happened? Do you have any other info as to readings or anything?
    A tripped rollout ain't a good sign.
    How old is this thing? This rollout, its over the burners or in the collector box, or...?
    New Boston, TX
    what is the best way to test for a cracked heat exchanger, I read several books and still cant get a good answer?
    New Boston, TX
    after I reset the limit, I turned the heater on and it did not roll out, I tested the unit about 10 times, the limit is on the collector box
    Sounds like the chimney backdrafted, if this is an old gravity draft model
    Probably would be prudent to check that it's not partially blocked or something
    Sometimes that kind of thing just happens, if it's excessively windy.
    Diamond, Ohio
    After changing the gas valve, did you check to outlet gas pressure?
    New Boston, TX
    yes i did check the outlet pressure, checked out...
