Results 1 to 6 of 6
    May 2011
    North Carolina
    Weather jar issue
    I just upgraded an FX20 to use the weather jar version 3.6.47. When I drop the weather service from the pallet tot the services under the station. When I double click on it to set it up I get an error that says:
    xxx.xxx.xxx.123|fox:|station:|slot:/Services/WeatherService
    can not hyperlink
    I'm running the JCI workbench version 4.1. I've got dns server and default gateway in the JACE. I'm not sure why it is doing this. Any ideas?
    On the bay fishing
    Module loaded on th FX?
    Beware of the prophet trying to make a profit.
    There is less oxygen from knee level to the floor! Check it out next time you tie your boots.
    May 2011
    North Carolina
    Yes. Weather.jar is loaded on the FX. If I go to a WB version 3.0 the weather service works on the same station as it should. Must be a WB issue or software installation issue?
    NY
    Is the latest distribution files loaded in the FX?
    "Controls is a lifestyle not a job" -klrogers
    May 2011
    North Carolina
    Dapper not sure i undetstand. I upgraded all out of date jar files on the jace. Not sure what distribution files you are talking about.
    Nov 2012
    you have to upgrade the Jace to the same version of the Jar Files?
    You have to pay the upgrade.....
