Results 1 to 13 of 15
    I'm in the process of purchasing a 3.5 ton system (type/model still unknown - until say midnight) and I'm told by one of the three vendors I've spoken to that if I'm to purchase a system with a seer rating of higher than 14.5 that I might need to purchase an R410 system instead of a r22 and, if so, will need to "swap out" the existing copper in my home. My house is 10 years old. Is this correct?
    PA/DE area
    it is recommended,due to oils also size of line may need to be larger.They can be flushed if they are the right size.
    It's NOT the BRAND,it's the company that installs it!!!!!
    I think the Trane XL15i and XL19i may be the only R-22 systems out there that go 15 SEER and higher on R-22.
    As I've indicated in another post I'm purchasing a Goodman system and I'm not sure if the "system" is 15 seer or if it's just one of the components. If so, I'm again confused as I'm not sure if it's possible to have one component that's that high while the rest remains "within r22 range". Thanks guys and again, any help is appreciated.
    Amory Mississippi
    If you have not already purchased it, re-evaluate. 410a systems give you more efficiency with smaller size. yes you have to change the line set. Yes it will cost more, but you will get more for your money.
    JMO
    Oct 2006
    Emerald Coast, FL 30.1N 85.8W
    Frown Do you need a 3.5 ton system?
    I get nervous reading some of these posts about residential system tonnage, especially the ones in the 3-5 ton range.
    Since most AHU's are designed around 0.5 SP, an oversized tonnage system is ridiculousy inefficient.
    My home is 2000 sqft one level. The existing unit is 3.5 tons as are most of the homes in my subdivision. Home size also matches mine as the average is between 1900 and 2100 sqft. Not sure if this is done as a rote exercise as these values match those detailed in all Zone 1 homes. I live in Florida.
    Oct 2006
    where at in Florida -- I'm in Panama City Beach.
    I spoke with a GC today building a high-end 2 level home. The 1st floor is 1800-2000 sf and I questioned him installing a 2.5 ton unit on the lower level(2nd level will have a seperate unit). He said that they will be downsizing to a 2 ton unit. The house will have R-30 insulation.
    All I'm saying is please be prudent when purchasing your new system -- the higher SEER rating might allow you to operate a smaller, thus more efficient unit.
    [Edited by emcoasthvacr on 11-28-2006 at 09:04 PM]
    SW FL
    EM,
    1. 2-ton for 2,000 Sq. Feet is likely NOT an acceptable selection ( unless the house does not have any windows and ACH is < 0.15).
    2. Higher SEER has NOTHING to do with capacity!
    Designer Dan
    Oct 2006
    2 tons is enough for lower level
    Don't know what part of Florida you're at(SE,SW, central, panhandle).
    The windows are low LOE windows, and since we're on the beach, temps rarely get above 90 degrees. In addition, the front & back porches are facing the rise & fall of the sun. The windows are facing the North & South; moreover, the Medjool Palms (175k for those puppies) provide shading. I believe the roof & 2nd floor are rated at R-55, and I need to double check the 2nd floor tonnage.
    The 2nd floor heating load and insulation in the roof dictates what tonnage is required on the lower floor.
    The builder designs homes above 1 mill, so I trust his 30 years experience and his P.E's that agreed with the 2 ton.
    Your right in that SEER doesn't dictate capacity, it just delivers it at lower costs -- didn't think I worded the sentance like that.
    [QUOTE]Originally posted by dan sw fl
    [B][QUOTE]Originally posted by emcoasthvacr
    [B]I spoke with a GC today building a high-end 2 level home.
    [Edited by emcoasthvacr on 11-29-2006 at 07:09 PM]
    Apr 2004
    The refrigerant plays a very, very small part of the higher efficiencies. The reason you dont see much R-22 in the ultra high efficiency stuff has more to do with economics. The manufacturers can no longer sell systems with R-22 in them come January 2010. It costs alot of money in research and development to develop a product so it makes little sense to develop one that will go away in a couple years. In most cases, they would never see a payback.
    Oct 2006
    doc holiday to the rescue...lol
    All my air conditioning & heat pumps on my properties are R-22. I'm not a fan of R410a, but I quess I'll have to be sooner or later.
    My main concern with R410a is not only the higher system pressures and subsequent component stress but also the higher costs of recovery, recycle, and reclaim that will accrue due to the varying vapor pressures of the R410a mixture.
    I also don't understand why residential customers have to bear the burden when the commercial & industrial entities are allowed to spew out tons of CFC's legally each year.
    [Edited by emcoasthvacr on 11-29-2006 at 09:05 PM]
    Pensacola, Florida
    Again higer efficiency has nothing to do with capacity.
    A 15 SEER 2 ton unit is 2 tons.
    A 13 SEER 2 ton unit is 2 tons.
    Torch Man
