Results 1 to 13 of 19
Thread: Inficon tech-mate
12-18-2012, 12:34 PM #1
- Oct 2008
- Ventura, CA
- 34
Inficon tech-mate
Anyone having problems with the sensor on the Inficon Tech-Mate dectector?
I bought one brand new about 6 months ago and used it once. Didnt work when i needed it a few months later. Had distributor send it
Back to factory. Replaced sensor. Tried to use it again a few weeks later. Same problem. Is sensor breaking when unit is being subjected to vibration and/ or mild bumping around while in my truck? I keep in the case but maybe thats not protecting it enough?
I cant horse around with keeping an important piece of test equipment on my truck that i cant count on.
Thank you.
12-18-2012, 12:49 PM #2
My Experience has been put that ucker on the shelf and choose a different brand.
12-18-2012, 03:54 PM #3
- Oct 2008
- Ventura, CA
- 34
12-18-2012, 04:35 PM #4
- Jun 2012
- Northeast
- 115
We have about 4 in our shop all on guys trucks. Never had any problems. Maybe you should exchange it. Tell the supply house you want a new one.
I have also been happy with CPS in the past.
12-18-2012, 05:46 PM #5
- Oct 2008
- Fullerton
- 704
The Tech-mate is a heated diode leak detector. The diode starts decaying the moment it touches air and will decay faster as refrigerant hits it. Typically they'll last a few years but they do get less sensitive the more they are used or sitting around. This is how heat diodes work. They sense the burn of the sensor. If you don't use it all that often I'd recommend a leak detector with an infrared sensor. Both Inficon and Fieldpiece make one. The infrared sensor doesn't decay as it's only looking at how the refrigerant in the chamber is blocking light. Here's a video demoing the Fieldpiece Infrared.
12-18-2012, 07:08 PM #6
- Jul 2012
- Cincinnati ohio
- 101
I bought and used one for 1 season and only found 1 leak and tons of false positives. At the beginning of this past season I bought the field piece/ robin airs infrared detector, it costs twice as much as the tech mate but you will make money back with a reliable detector. You don't get false positives with a infrared detector and it works great with 410 unlike heated diode types.
12-18-2012, 09:06 PM #7
- Nov 2011
- Charleston, Wv.
- 686
I've got a tech mate. no problems here. we had another one at the shop, was beeping like crazy all the time, replaced sensor, and no problems out of it either. and it does sense 410. for the price, they do a good job.
are you saying they sent it back to the factory for a sensor replacement? all you gotta do is pop the rubber cap off and replace it.....United stocks sensors.
sounds you got a lemon.
12-18-2012, 10:33 PM #8
- Jul 2012
- Cincinnati ohio
- 101
12-19-2012, 11:36 AM #9
- Oct 2008
- Ventura, CA
- 34
Thanks for your reply.
I bought it from United but manager didnt know what was wrong with it and because it was under warranty, he sent it back. I suspected a bad sensor but he didnt have any in stock.
12-19-2012, 11:41 AM #10
- Oct 2008
- Ventura, CA
- 34
Thanks for your information. Ill pass it on to the manager at United Refrigeration.
So frustrating (and costly) when you drive a long distance to fix a leak and finding out after you get there, your new leak detector doesnt work. Murphys Law at its finest.
12-19-2012, 11:45 AM #11
I was and am speaking from experience I have had nothing but problems with that leak detector so I bought a Bacharach, no problemos. Oh except when I lost the freaking sensor.
12-19-2012, 11:46 AM #12
- Oct 2008
- Ventura, CA
- 34
Thanks a lot for your information!
Ill look into an infrared detector. Im so tired of false positives. I knew there had to be something better out there.
12-19-2012, 11:47 AM #13
- Oct 2008
- Ventura, CA
- 34
Thank you for your reply!
