Results 1 to 13 of 14
    Sep 2006
    Ma.
    Hmm
    Any one know where I could fine a 10 seer condensor unit
    Make: Armstron High efficiency 10
    It's a 2 tone unit. I will try to find the exact # numbers for anyone who may know where I can find it. It has a junkl compressor and Copeland doesn't make a replacemnet for it.
    Florida
    How old is it??? Someone will have a compressor for it, even with different piping. 10 seer's are hard to come by, expect to pay premium, as the contractors scarfed them up. If yours is over 10 years old, replace both with higher seer IMO.
    Ya good luck on that one. Would be worth more then a 13 seer now if you even could find one.
    NW burbs of Detroit
    so you want ten SEER?
    Welcome to our world.
    Somebody has a comp for that unit. Keep looking.
    It'll be cheaper to repair then replace, at least in this case.
    Colorado flatland native
    Originally posted by kpaul
    It's a 2 tone unit.
    What are the colors?
    2 tones is 2 tones. Copeland might not make an EXACT replacement, but they make a 2 tone that will work.
    Walter Matthau
    Sep 2006
    Ma.
    So on the 2 tone ( Sorry my spell check isn't working)
    Full time job and 3 kids, a life , makes for quick posts.
    Figure you were smart enough to figure it out.
    Any one who has any thoughts on were to pick up a 2 ton 10 seer appreciate it, English majors thanks for the cracks!
    Peace.
    Hummm ... probably can get one on the black market. I think if you dicker with them you could trade 2 of your kids for one unit........ that would at least leave ya one.
    Depending on what your wifes like ...... you may not have to give up any of the kids.
    no Im not kidding lol
    Aug 2001
    forney texas
    I have a 2 1/2 ton carrier heat pump, i think it might be 2004, it was hooked up but never started and a 1 1/2 ton payne still good but used
    Jun 2006
    northern Il.
    We have a New 2ton 10 seer Goodman, where are you located?
    Sep 2006
    Ma.
    ma.
    Northeast PA
    See if you can locate and post the #s from the old compressor. I'm very sure someone here will be able to recommend a functional replacement even if it isn't a Copeland. Should be easy to pick up at a local United Refrigeration.
    Make it fool proof and someone will make a better fool!
    berlin,maryland
    If your looking for a a/c unit not a h/p check united ref. stock.oceancity,maryland.last time I checked 400-500 in cd.It may have changed since then.
    be honest to yourself and your clients
    Sep 2006
    Ma.
    Thanks guys I appreciate it your input.
    I tracked one down.
