Results 1 to 8 of 8
    Altmar, New York, United States
    poll barn or basement?
    i am designing my new house to hopefuly build in the spring. i am torn between a basement or a pollbarn. they will both cost around the same to build. i have thought about both but i want to do this without a mortgage and at this time i can only cover one or the other. i would like a basement to raise the value of the house and for more room. but i need a barn for storage because i have 3 businesses. i have a shop for but it's 40 miles away and kind of hard to work out of. i would love to bring all my stuff up here. i am leaning toward a 30 by 30 barn. what would you do?
    May 2012
    Upper Michigan
    A basement turns into a junk pit in a hurry, do a house on slab with in floor and save money on time and parts. I have a full basement and really only use it for storage and mainly stuff that should be in the dump. I'd rather have a pole barn.
    Mar 2009
    Several Miles from Sane
    It costs less to add a pole barn later than it does to add a basement, later. The basement will have value from the beginning.
    Pick the basement then add the pole barn next year
    If sense were so common everyone would have it !
    Any advice provided is worth exactly what you paid for it, not a penny more not, a penny less !!
    Quote Originally Posted by Cagey57 View Post
    i agree. i wonder if the barn would add close to the value of a basement.
    Atlanta area
    A basement is a great place to put your heating system, water heater, washer-dryer, dehumidifier, circuit breaker box, tornado shelter, small workshop, extra bedroom, extra bathroom, office, freezer, pantry, extra cupboards and closets. And most of these are things you can add as you need them. How many of these would you rather put in a pole barn, or cram in a closet or attic?
    Five or ten years from now, would you rather have regrets or options?
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
    burlington county n.j.
    basement now, pole barn in the future.
    and go bigger, mines 42x48 and full of stuff.......
    Rapid City, SD
    I have a basement, and it's useless. Of course it's poorly finished, poorly heated, and full of junk.
    I do think a basement would add more value to the place, even if it's unfinished. If you're never planning on moving that might change your opinion though.
    I say go big tho... think outside the box!
    Put a basement under the house. Then in a few years build yourself a nice polebarn... with a partial basement under one side of it too. Then you can put a tunnel between the 2 basements!
    Quote Originally Posted by amickracing View Post
    i love it!!! i don't see the tunnel happening though. but it is something i will absolutely look into.
